I read a lot of stuff in different forums about the RNS-315 in a MK5. It seems the the head-unit should work fine, but no MFSW buttons (for all MK5) and no display in the MFD (for those who have the RED MFD+, it works completely on the WHITE MFD+).
What was a no go for me at the beginning was the lack of the MFSW buttons because I like to change the volume and hang up my phone calls without leaving my eyes from the roads.
So I finally decided to buy one of them and here is what i found by myself :
On my 2009 Jetta TDI Sedan (Highline) , my MFSW is working with the RNS-315 (1K0 035 274 B) (volume +/-, phone, mute) but for now I do not have any information from the RNS-315 in my MFD+ (the RED one). So the basic functions of the RNS-315 seems to be able to cummincate with the car, even if they do not use the same protocol (BAP for the RNS-315, DDP for the MK5).
But as my Jetta is the latest real MK5 model, maybe it has some MK6 parts (CAN gateway, Steering Module, and some others)
I did not try to do any VCDS coding for now (I am waiting for my mic harness), but it seems, at least with the 2009 MK5 to be more compatible than expected by many other people.
If I am able to add some other functions from the RNS-315 to my MK5, I will let you know.
What's the build date? It's on a door jamb sticker.
It should use only mk5 electronics if it has the red MFD. Since I haven't seen this for myself, any way you can upload a short video showing the MFSW operating the rns315? If so, I'll update the rns 315 FAQ with your findings and of course, give you credit! I don't like to add things to the FAQ unless I see multiple reports or proof since your car could be a fluke.
As soon as i am in my car, i will check this out and make a video. I am just missing the mic harness and the am/fm adaptor to have bluetooth phone and radio ;-)
Thanks for the find! Article edited. and credited with your find. Your car is a mid model year build. They started making them in late 2009 and 2-09 means 2nd week of 2009, not Feb 2009. The production dates usually end around June.
Here is my VCDS report made this morning (I have errors with the RNS-315 because I do not have the antenna adapter yet (Radio and Sirius but I do not understand why I have an error for the AUX)
Address 01: Engine (CBE) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 997 016 P HW: 03L 906 022 J
Component: R4 2,0L EDC G000AG 8681
Revision: 12H01--- Serial number: VWX7Z0I024I0HL
Coding: 0050078
Shop #: WSC 00066 000 00000
VCID: 3F875D256E669D1
No fault code found.
Readiness: 0 0 0 0 1
Address 02: Auto Trans Labels: 02E-300-0xx.lbl
Part No SW: 02E 300 051 HW: 02E 927 770 AJ
Component: GSG DSG AG6 431 1814
Revision: 04943012 Serial number: 00000807140375
Coding: 0000020
Shop #: WSC 02069 000 90108
VCID: D0A5EE9943F8929
Address 03: ABS Brakes Labels: 1K0-907-379-MK70M.clb
Part No SW: 1K0 907 379 AF HW: 1K0 907 379 AF
Component: MABS MK70M 0104
Revision: 00H32001
Coding: 0016641
VCID: 76E9F80101DC1C9
Address 08: Auto HVAC Labels: 1K0-820-047.lbl
Part No SW: 1K0 820 047 JE HW: 1K0 820 047 JE
Component: Climatic PQ35 143 1313
Revision: 00143033 Serial number: 00000000000000
Shop #: WSC 00000 000 00000
VCID: 70E5CE1963B8329
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C8 937 049 D HW: 3C8 937 049 D
Component: Bordnetz-SG H54 2602
Revision: 00H54000 Serial number: 00000001169863
Coding: 10018E234004150007140000001400000008730B5C000120000000000000
Shop #: WSC 00066 123 12345
VCID: 32610411AD34409
Subsystem 1 - Part No: 1Q1 955 119 C
Component: Wischer 280912 026 0512
Coding: 00065493
Shop #: WSC 00066
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 AC HW: 1K0 909 605 AC
Component: 2V AIRBAG VW8R 038 8600
Revision: 07038000 Serial number: 003E7M08B5L5
Coding: 0012886
VCID: 6DDBD76D748ADF1
Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
Part No SW: 1K0 953 549 CD HW: 1K0 953 549 CD
Component: J0527 055 0111
Coding: 0001431
Part No: XXXXXXXXXXX
Component: E0221 002 0010
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No SW: 1K0 920 874 D HW: 1K0 920 874 D
Component: KOMBIINSTRUMENT 3HL 2418
Revision: V0002000 Serial number: VWX7Z0I024I0HL
Coding: 0023303
Shop #: WSC 94756 999 83917
VCID: 2E591061B90C649
Address 19: CAN Gateway Labels: 1K0-907-530.lbl
Part No SW: 1K0 907 530 S HW: 1K0 907 951
Component: J533 Gateway H07 0071
Revision: H07 01 Serial number: 221108F1001810
Coding: ED807F06401202001002
VCID: 377735054656A51
Address 1C: Position Sensing Labels: 1Kx-919-xxx-1C.lbl
Part No SW: 1K5 919 965 A HW: 1K5 919 965 A
Component: Kompass 005 0004
Revision: 00005000 Serial number: 1293324T3N3K04
Coding: 0000003
VCID: 3973333D7042B31
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO 3HL 2418
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 B HW: 1K0 035 274 B
Component: RNS315-NAR H33 0265
Serial number: VWZAZ2L8478807
Coding: 04000401010005000000100A
Shop #: WSC 01357 011 00200
ASAM Dataset: EV_RNS315NARV2UDS A01004
ROD: EV_RNS315NARV2UDS_VW36.rod
VCID: 234FF1552ACED91
Data medium:
Subsystem 1 - Part No: 3AA 919 866 B
Component: NAR_V2 0002
6 Faults Found:
1048629 - Aux IN Socket
B1104 13 [009] - Open Circuit
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 215
Mileage: 97898 km
Date: 2000.00.00
Time: 11:11:19
1048632 - Antenna 1 for Radio
B1119 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 215
Mileage: 97898 km
Date: 2000.00.00
Time: 11:11:17
1048634 - Antenna 2 for Radio
B111A 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 215
Mileage: 97898 km
Date: 2000.00.00
Time: 11:11:17
1048667 - Antenna for Satelite Radio
B10F4 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 215
Mileage: 97898 km
Date: 2000.00.00
Time: 11:11:17
Another weird thing. My cluster and my RNS are time synchronized. But I can not get any information in the MFD (due to the lack of BAP protocol in it).
How is all this possible ? I do not understand. Some parts are working, other not.
The cluster sends time data to the RNS 315 to calculate ETA, etc. I wasn't even sure if it'd work because of BAP. The MFSW ability is because you have a newer control module. I think it will just not show stuff on the MFD because of BAP.
No, only 1 side, off the top of my head, the right side. Some more detailed info in the MFSW swap article. Steering wheel and airbag will otherwise work.
I have a 2009 Jetta TDI build date (2-08), I am seriously looking into installing a RNS 315 or RNS 510 in it. I am NOT concerned about displaying on the red MFD. My major concern is that the steering wheel volume, mute and phone buttons work and I want blue tooth to work (one of the main motivators for this project).
Having read this thread my questions are:
1. Did you get this to work with the original 09 Jetta steering wheel control module (you talked about put a new steering wheel control module in only your 08 Rabbit?)
2 If there is a difference in the can bus/steering module between 02-08 and 02-09 builds would I be able to get it to work with a new steering wheel control module like your 08 Rabbit?
3. My stock radio has sirius, will the current antenna just plug into it? I know I will have to disconnect the compass module!
4. Will a blue tooth module be required or will the RNS-315 or RNS-510 provide full blue tooth functionality on its own?
Can you think of anything I might not have covered?
I have a VCDS so I will be able to code any changes required, providing I get good advice.
anyone have a link to a store with a sirius antenna extension that will work to bypass the Premium 7 sat module to use a Premium 8 radio (RCD 510)? No intention to hijack thread felt it was related.
Hello,
Gonna wake up this old thread and give some extra info about this combo.
So i just installed a rns 315 in my 2008 golf variant.
I have a full MFD and steering wheel buttons.
Ofcourse nothing worked. But I had read about a PolarBT box, the box makes it possible to use a BAP bluetooth module in a MK5 with everything working. So i thought maybe that box will translate the BAP code from the RNS and make it work fully in the MK5. Short answer, it doesnt do a lot.
The left side of the steering wheel controls started working and in the MFD a Telephone page was added, but theres nothing on that page.
This is the box connected with the included loom.
And this is the telephone screen on the MFD.
So for the people researching if this would work, it sort of does...
Related Threads
167K posts
102.1K members
Since 2007
