1 - 7 of 7 Posts
Hello,
I heard, that 1.9 PDTDI BXE and BLS engines have some issues with the connecting rod bearings and screws.
Some say, that only the screws are problematic there, and some say that the bearings too.
My A3 has a BLS engine. I have no problems with the car, I just want to prevent an engine swap.
Could someone tell me, if only the screws are advised to replaced, or the bearings too?
If I'll replace the bearings, do I have to do any measurements and choose oversized bearings if neccessary, or if nothing happened yet, standard size is enough?
The car ran 310000 km so far, first owner and oil is changed after every 15000 km.
Thank you,
Reading this it sounds like it's mainly the BXE lump
http://www.audi-sport.net/xf/threads/bxe-engine.146231/
Not sure what you'd replace or upgrade though
I digged further in the topic and this is what I found:
It is mainly a BXE problem, but BLS engines also affected. The BKC, which was before these two, is not affected. The BKC block is slightly different and has a different crankshaft: 8 counter-weights instead of 4. If oil service is done after every 30k km instead of 10k or 15k, it will happen sooner. Most of the cases happened with engines from 2008.
Also found some information about how the screws of the conrod break: Upper bearing starts to wear off slowly, then seizes, slips down and so breaks the screws.
Solution: I couldn't find any good, permanent solution, apart from rebuilding everything on a BKC block and crankshaft. As a non permanent solution, replacing the bearings and the screws is a good idea.
If someone replaced the bearings before, what exact manufacturer would be the best? Is there an upgraded type, which is more durable?
Also, if I did not modified the crankshaft, there is no need for under- or oversized bearings, am I right?
You only use oversize bearings when you've had the crankshaft reground.
Title changed to mean something logical. ;)
Hi everyone, sorry to bring up an old thread but has anyone replaced their Conrod bearings on the BXE engine ? Are the new bearings modified/ better to prevent failure ? I have a BXE and don't want it to go bang so I want to replace my bearings but unsure which ones to use, it's a 2007 on 68000 miles
Thanks
Thanks
Release Notes
Which model with the BXE engine as there are 18 VAG models that use the BXE?
My apologies I was just sweating a bit reading about this failure ....sorry will post intro .....it's a Skoda Octavia 2007 BXE engine... cheers.
1 - 7 of 7 Posts
