Just swapped in a new exhaust control valve from autohaus, getting the same P048C - 000.
Why I suspect it is a cable:
-The 000 part which is 'implausible signal', (aka nothing?)
-I moved the flap on old part and it feels same as new.
-Before replacement I disconnected wire while troubleshooting. I oiled the external spring, worked it a little and the CEL went out. CEL came back on by itself shortly before part replace.
So is it a bad wire or connector? Or.... what?
If so, leads to threads on continuity/power check pls. Yes I did a search.
Attached is the fault sections of the fresh scan. The clogged filter is likely due to it not being able to regen because of flap. The 'EGR system' fault is new, was not on scan from a week ago.
Thanks!!
VCDS Version: 14.10.2.0 (x64)
Mileage: 180840km-112368mi
Chassis Type: FM (8P0)
Scan: 01 02 03 08 09 0F 10 15 16 17 19 25 2E 37 42 44 46 4C 52 55
56 62 72 77
Address 01: Engine (CBE) Labels: None
Part No SW: 03L 997 030 R HW: 03L 906 019 CT
Component: R4 2.0l TDI G000AG 9983
Revision: 12H14--- Serial number: AUX7Z0JNFNB07H
Coding: 0350078
Shop #: WSC 51279 002 1048576
VCID: 3D76A1DB646209C9459-8068
3 Faults Found:
001164 - Sensor for Exhaust Flap
P048C - 000 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 2
Fault Frequency: 12
Reset counter: 255
Mileage: 179591 km
Time Indication: 0
Date: 2021.05.22
Time: 19:01:37
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.39 V
Lambda: 0.8 %
Lambda: -12.6 %
Bin. Bits: 00001110
Voltage: 1.140 V
008194 - Particulate Trap Bank 1
P2002 - 007 - Efficiency Below Threshold - MIL ON
Freeze Frame:
Fault Status: 11100111
Fault Priority: 2
Fault Frequency: 9
Reset counter: 255
Mileage: 180678 km
Time Indication: 0
Date: 2021.06.28
Time: 14:30:17
Freeze Frame:
RPM: 2116 /min
Speed: 106.0 km/h
(no units): 71.4
(no units): 20.4
(no units): 2.25
Pressure: 115 mbar
Pressure: 41 mbar
001025 - EGR System
P0401 - 001 - Insufficient Flow - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 180618 km
Time Indication: 0
Date: 2021.06.28
Time: 11:25:26
Freeze Frame:
RPM: 2162 /min
Speed: 109.0 km/h
Voltage: 13.60 V
Load: 79.2 %
Load: 100.0 %
Mass Air / Rev.: 310.0 mg/str
Mass Air / Rev.: 315.0 mg/str
Readiness: 1 3 0 0 0
Address 17: Instruments Labels: 8P0-920-xxx-17-MY8.clb
Part No SW: 8P0 920 982 S HW: 8P0 920 982 S
Component: KOMBIINSTR. VDO H01 0091
Revision: D0H01004 Serial number: 224NJ004002733
Coding: 0272288
Shop #: WSC 51632 001 1048576
VCID: 499EC50B20AAA569F91-801C
1 Fault Found:
00003 - Control Module
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 180847 km
Time Indication: 0
Date: 2021.06.30
Time: 17:10:50
Thanks!!
56 62 72 77
Coding: 0350078
3 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 12
Reset counter: 255
Mileage: 179591 km
Time Indication: 0
Date: 2021.05.22
Time: 19:01:37
Freeze Frame:
RPM: 0 /min
Speed: 0.0 km/h
Voltage: 12.39 V
Lambda: 0.8 %
Lambda: -12.6 %
Bin. Bits: 00001110
Voltage: 1.140 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 9
Reset counter: 255
Mileage: 180678 km
Time Indication: 0
Date: 2021.06.28
Time: 14:30:17
Freeze Frame:
RPM: 2116 /min
Speed: 106.0 km/h
(no units): 71.4
(no units): 20.4
(no units): 2.25
Pressure: 115 mbar
Pressure: 41 mbar
001025 - EGR System
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 180618 km
Time Indication: 0
Date: 2021.06.28
Time: 11:25:26
Freeze Frame:
RPM: 2162 /min
Speed: 109.0 km/h
Voltage: 13.60 V
Load: 79.2 %
Load: 100.0 %
Coding: 0272288
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 255
Mileage: 180847 km
Time Indication: 0
Date: 2021.06.30
Time: 17:10:50
