I removed the Mechatronics unit from my 2006 Jetta TDI DSG transmission so that I could replace the (G182 transmission input speed /G509 clutch oil temperature) sensor. When I loosened the ten Mechatronics retaining screws (that are supposed to be replaced and I have new ones) I accidentally loosened another T27 screw that looks like it is one of the many screws actually holding one of the eleven solenoids. (All the screw heads look alike.)
And now that I think more about it, I am not sure that they are solenoid screws. I did attach a photo for clarification. There's nothing in my manual about this.
Does anyone know the correct torque setting for these screws? This one is about an inch long whereas the ten Mechatronic screws are about an inch and a half.
Should these other screws be replaced also, like the ten Mechatronics unit screws.
I want to be precise about this because it took so much work to remove the transmission (for clutch pack replacement) and get to this point. Also don't want a failure because a screw failed.
The 2005-2007 Volkswagen Jetta Quick Reference Specification Book (found on eBay) has been a huge help with torque settings, but it has nothing about the solenoids.
(BTW I have checked the solenoid resistance and they are all as specified.)
Thanks for your help.....
