Hi all. New member here. I've got a leaking rear main seal on my '02 Jetta TDI. It's been a slow leak for a couple of years, ever since I replaced it while installing a new clutch/SMF. Without removing the tranny I'm not sure of the exact cause of the the leak, but I'm going to replace the seal soon. I realize that it's a teflon seal that has to be installed dry.
My engine has 207,000 miles now, so I'm thinking that perhaps the crank may have a slight groove at the seal contact circumference area that is causing or contributing to the leak. As an ounce of prevention I'm thinking about installing a Redi-Sleeve on the crankshaft to create a new, ungrooved area for the seal to contact. From what I have gathered it would be Redi-Sleeve #99333. Have any of you installed one of these Redi-Sleeves? It seems to be a simple procedure. Thanks in advance for any info/tips.
