Vw Jetta pd tdi 1.9 hiline, rear view mirrors not opening while rotating the switch to any of the positions but some times the left side mirror opens a little( almost half) but no movement on the right side mirror when left mirror moves joy stick operations are also fine other wise the stick also not functioning
I don't have a vag, by using another device scanned but no issues found on modules what could have gone wrong this happened after the lock down period for corona thanks in advance
Welcome to the forum.
Of course,I don't have vag, but ihave scanned the motor with some other scanner couldn't find any error in it .
From the symptom shown by the mirrors
I feel like some over load on mirror motor(may be stuck gears or motor it self)on the right side. Tomorrow I'll disconnect the right side mirror electrical jacks and check, then I'll post the results ok, thanks for encouraging me with your valuable feedback Iam an old member of the forum but inbetween I couldn't login to forum
