I'm replacing my rear brakes on my 2002 Golf TDI GL. It amazes me how one little screw has messed up the whole operation.
Driver side, everything came out without a problem. Passenger side, not so much.
Like many people, my rotor screw started to strip. I used an extractor bit, which succeeded in fully stripping the head. Decided to drill off the head, which worked. But the remaining screw was too short and too soft to get a grip on. Tried drilling the screw out, and ended up with a nice hole all the way through. Tried extractor bit inside the new channel, which ended with the extractor bit breaking off inside the screw hole.
Used a punch to get the broken bit out. Tried a different extractor bit, but the remaining screw seems like it has just melted into the wheel hub.
Tried using the non-damaged rotor screw from the driver side to create a path, but all that did was damage the other screw (the metal is so soft).
So my question is, which option(s) do I try next:
I found some machine screws that fit the rotor hole flare and are almost the same length. Do I try to use those in place of the flimsy dealer replacement screws? It seems like the rotor screw doesn't take a lot of a pressure, but I don't want to think I've fixed the issue and end up in worse shape down the road. When the wheel is on, does the rotor screw matter since the lug nuts hold everything in place? Am I missing something here?
Do I drill out the old screw hole and try to create a new tap?
Is there a way to get the soft/melted/stuck old screw remnants (basically the thread and a small layer) out without damaging the hub?
At what point is it easier/better/safer to buy a new wheel hub? If I replace one side, should I replace the other at the same time? Are the right pullers for that job available at a place like Autozone?
Thanks for any help or ideas.
