I've got an 04 Jetta and it's got a rattling noise at idle. It changes if the rpm is raised, a/c is turned on or steering is turned. I tracked it down to the serpentine belt and the tensioner, it's moving quite a bit. If I put some pressure on the tensioner the noise goes away. I'm planning to do the timing belt next month and will replace the serpentine belt and tensioner at the same time.
Just wondering if anyone else has had this problem?
Tbone
Tbone
