Will a factory gps radio out of a mk5 fit in my mk5 that did not have gps? The plugs look the same but will it work?
That isn't an easy question to answer on a forum.
Which radio/sat/nav model is it?
Do you have the shark fin aerial fitted on the roof for sat/nav?
Have you coded this new radio with the radio code?
Do you need Bluetooth?
