Thanks for the reply. Actually, do you think you could post the part numbers? I remember stumbling across the GLI part numbers somewhere, so that might be a good place to start.
As for the DSG/manual bit, this is the weird bit. I know the GTI has different part numbers for the manual and DSG, but the color codes I've seen for the manual and DSG GLIs have been the same. Perhaps I haven't researched enough, but I'm not able to find much information regarding that, but I did find it puzzling to see the same color codes.
Edit:
@pearlgolf
Yeah I know I can still swap them, I just want to avoid any major differences in spring rates. Although, it shouldn't be that different because the weight difference is under 100 pounds. Still, I'd like to confirm that.
