Also fixed some dead links.
You can view the seal replacement article here. Have yet to add the part numbers for the sensor and seal though, someone asked about this so I just whipped up a write up quickly.
this only applies to 1996-2003 models that use an injection pump since the pumpe duse cars don't use this type of sensor or injection pump. Although the IP is different over the years and auto/manual trans, they all use the same seal and temp sensor
http://www.myturbodiesel.com/1000q_how_to/multi/fueltempsensor.htm
