Not sure where else to put this - so I decided on this forum.
So I'm swapping in a TDI from my 2000 Golf donor - along with a bunch of accessories and anything else I wanted from the donor.
Originally, I had wanted to swap into a 1981 Rabbit that I have, but then I found a gutted 1987 Scirocco MK2 and decided it would be a better recipient. Now I can keep my perfectly functioning '81 diesel rabbit along with my monster scirocco.
I've learned that I was quite unlucky with my choice of donor car, I found a rear ended tdi for a decent price quite near where I am doing this swap and jumped on it. Unfortunately for me, this car had a few issues.
So now, I've removed nearly everything from the car donor, I have the wiring harness in the car (9 hours of soldering after having to cut it in half :eek). And I'm waiting for my new VNT-17 to arrive before installing that, finishing the timing belt job, and installing the new clutch. Hopefully Chittychittybangbang will be back to help me out again. He's a great guy and extremely knowledgeable and helpful (as is obvious by this website alone!).
So that's where I'm at now. I spent 8 hours today trying to make a bracket for fit the throttle pedal in a decent place reliably... I'm not sure how well that's going to work considering the bracket is made of 1/4" steel plates in the most bizarre arrangement... I need to cut out some of the air duct to the foot well to fit it properly, I hope that works out?
Then I'll be installing the shifter assembly, cutting holes into the firewall to run the cables. I hope it won't sit too far forward and interfere with the console. If it does, then I'll just have to modify the console/shifter.
Once I finish the engine upgrades then it should be set to drop into the car and start wiring it all up. I'll be using the stock exhaust for now, until I can acquire and fab up some new 2.5" exhaust piping.
I'm in the need of some A1 engine mounts though, since the scirocco didn't come with an engine, it also didn't come with the mounts or brackets unfortunately. So I'll need to find some of those, as well as a new lower right control arm which was bent during transportation... Also I'll need to reroute some fuel lines and figure out how to eliminate the CIS fuel pump (pumps at up to 120 PSI!) or regulate it or something...
So, still much to do!
It'd be nice to be able to remove the seats too, but they aren't stock and I'm not exactly sure how to remove them. They are powered Recaro touring seats (I think??). I'd also like to reupholster them if I can get them out.
Wow... well that's long enough, I need to get some pictures up!
Anyone by NYC who is interested/would like to contribute in any way to to this project feel free to send me a PM.
:needpics:
anic:
Since I hate not having any pictures up:
picking up the 'rocco
When i first started taking apart the golf
Engine out
mostly gutted
That's all I have right now, except for a couple pictures of me in the scirocco engine bay - but I'll need to fish those out of my email.
I need some current pictures, these are old (a month?)
:needpics:
Engine out
mostly gutted
