1 - 9 of 9 Posts
I have a 2006 Jetta TDI .
The problem is the drivers window rolls up backwards You push the button down and it goes up. You lift the button and it goes down. All the other windows operate correctly. Any ideas whats wrong?
Thank you in advance
Discussion Starter · #7 ·
I bought the car new and it worked fine Last fall the window stopped working.Went to dealer and they diagnosed it with broken wiring harness. They repaired it (one wire) and the window has not worked the same ever since. They called me and asked if it always worked like this (no) So I replaced the switch, it and that didn't change the operation. Then I changed the wiring harness and still no change.
1 - 9 of 9 Posts
