Hi all, this is a proud new owner of a 2011 Jetta. Name is Bob Munro, living in Comox,BC., Canada The reason I searched and found this great site is because I heard there had been a problem with power loss on the 2009/2010 deisel engines. Has anyone had this problem? Forwarned is forarmed. Call me bobcat
Hey bobcat, you're probably thinking of problems with the high pressure fuel pump. Here is one thread that talks about it. Your engine/transmission is the same as the 2010 models. The 2009 engines were slightly different and the manual transmission also slightly geared differently. http://www.myturbodiesel.com/forum/f7/dweisels-hpfp-analogy-failure-4187/
The number affected is fairly low but unless it's covered under warranty it could be a major headache-expense.
welcometomyturbodies
Discussion Starter · #4 ·
to seatman
I appreciate the welcome seatman,sounds like you have fine a fine set of wheels. must have good taste all around, marrying up with a Scot.My folks came from the Argyle area, what about your wife's.
