I changed the timing belt today on my 06 TDI BRM with 192K. It was my first time changing the belt on the VW but I’ve changed timing belts many times on other vehicles. I followed the instructions from Exo VCDS on YouTube.
I used the proper cam lock and crank lock and am very confident that nothing moved when doing the job. I did have to loosen the 3 cam pulley bolts to get the crank locking tool into position once I had the cam pin fully inserted. I moved it at most about a half a tooth, I assumed this was off slightly due to belt stretch. I had to go back and forth a few times to get the cam pin positioned correctly. I retightened the cam bolts after putting on the new belt.
I was able to get everything back together without issue, started it up in neutral while it was still on Jack stands and all seemed fine after an initial back fire. I revved it to about 3-4K all seemed good.
But when I took it for a test drive I am getting surging when at about 3k rpm. I’m not getting any error codes.
I was thinking that it has something to do with loosening the cam bolts to get everything to line up? Any advice on what to try would be appreciated. I don’t have VCDS.
All the best,
Revvik
All the best,
Revvik
