I have had a slow leak for a WHILE, emphasis on "while". Or is it wile? I dont know, but what I do know is that I think I pinpointed the leak to the valve cover. What I noticed was that two of the thirteen brilliant torx screws on the back by the turbo and intake where a bit loose. At least loose enough to tighten them a bit with torx screwdriver -.-
I was thinking about buying some oil dye at work and inspecting it with a black light, but Im almost certain it is that because when I look at it after driving it looks like it has fresh oil coming out. I had a VW mechanic look at the turbo lines and he said they are not leaking. I would like to Inspect them myself but dont know how. Any suggestions?
Ever since the dealer changed my engine, and transmission I have had nothing but problems. One of the techs said I could have a possible egr valve oil leak and I laughed at him. I dont think and egr valve leaks oil unless this is a special car. Either way I would like to change out the valve cover gasket, my friend printed me out some instructions from AllData and it says to torque down the screws 10nm, and also mentions something about dry matting? Does anyone have any personal experience with this fix?
