Hello, guys!
I've got a 1.9 TDI, 130HP (PD) and I've noticed some serious stuttering at cold start. It idles at around 980 RPM with revs bouncing, after a few kilometers, revs drop down to normal - 903 and it gets a little smoother but I still feel some of this stuttering upon acceleration, also some serious vibration when I'm under 2000 RPM in fifth and sixth gear.
I've recently changed MAF sensor since mine was not working at all.
Also I recently had "launch control" mapped to the ECU.
Could it be the MAF sensor malfunctioning or the so-called mapper screwed up? Or do you have any other ideas why this could be happening?
Which 1.9 TDI-PD 131PS?
