1 - 9 of 9 Posts
plz can ne1 help me ive not long bought the car its a gttdi golf 130. its goin into limp mode around 60mph. i have changed the n75 valve checked all pipes, fitted new turbo changed fuel filter im gettin the fault code positive boost devation. gettin really annoyed with it now plz can ne 1 help wud be appreciated thanx
It could well be, the problem is if the boost isn't within certain parameters then the ecu doesn't like it and throws the car into limp mode so a leak in the system will cause the ecu to up the turbo I would've thought because the map sensor isn't getting the full picture, have you also checked the adjustment of the new turbo's actuator? There's a write up in the faq for it.:)
1 - 9 of 9 Posts
