Hi everyone i got this Jetta Tdi 06.5 BRM with DSG HXU that on 156k had DMF replaced due to failure, no pieces shattered to do any damage, happened in my driveway when I was getting ready to take off to work, after 2-3 months sitting I decided to take it to mech shop, got an original DMF Luke $400+ New rear crank main seal, and 5 liters +filter,
So the mechanics put it back together and now my car make sound when you put it into D or R as soon as you release the brake pedal(car still not moving), press the pedal the squeeling noise will stop, ok , let say I’m about to go, I’m adding on the pedal and car hesitate to start rolling and after a rough hit it’ll pick up the speed so from 1k thru 2k rpms then another second of hesitation and new rough hit and now it’s in 2nd gear, ... it’ll do it and In the third and the forth, but as higher gear it gets the hit mellows down and between 5th and 6th I don’t really feel rough shift pretty much, ive noticed leak every morning probably just little less than half pint
And when the car is cold it doesn’t shift that hard after 5 mins probably warm up time shit starting to happen, before the dmf was installed, this car shifted gears as smoothest as it can get
Even though you made a welcome to another member in intro.
