Hello everyone,
My question is how do I get a wrench on top of the passenger side trans mount. I felt up in there with my hand and there seems to be a heat shield in the way. Not like the drivers side which is open.
By the way I am reaching in through the wheel well opening.
Thanks
Chad
Remove the heat shield? One trick is to use your other hand. It lets you approach the bolt from a different perspective.
The way I did it is to use extensions snaking down from the top.
Also, post moved to mk4 technical.
