1 - 11 of 11 Posts
The car is running very rough. scantool shows code 00550, I can delete it and it shows up again on next start. Yesterday the car was fine werd . All I did on the car was ''Fuel tank venting FAQ and vent removal procedure'', and removed cover of the timing belt to see if everything is ok. :dunno
Possible Cause:
Wiring.
Fuel injection timing solenoid.
Injector needle lift sensor.
Air in fuel system.
Fuel level low.
Pump timing.
I can assure you that it's not related to the fuel venting. If you nudged a wire that was already chafing, it's possible that removing the timing belt moved it.
VAG Error Code: 00550
Fault Location:
Start of injection - control
Possible Cause:
Wiring.
Air in fuel system.
Fuel level low.
Pump timing.
EOBD II Error Code: 00550
Fault Location:
Start of Injection Regulation: Control Difference
Symptom:
Malfunction Indicator Light (MIL) ON.
Loss of Power.
Starting Problems.
Transmission in Emergency Mode.
Possible Cause:
Fuel Tank incorrectly filled with Petrol or Biodiesel.
Air/Water in Fuel System.
Injection Timing incorrect.
Electrical Fuel Pump faulty.
Possible Solutions:
Check Fuel Tank for Petrol and Biodiesel.
Drain Tank and Fuel System.
Check Fuel System for Air/Water.
Check Fuel Supply and Return Lines for Blockage and Leaks.
Check Electrical Fuel Pump.
Check/Correct Injection Timing.
Perform Basic Setting / Use TDI-Graph.
As taken from my http://www.myturbodiesel.com/forum/f9/free-eobd-ii-error-codes-software-2919/ ;)
Well it won't hurt to check it.
I'm not sure about this as I don't know the year of your Passat GT (please add this to car spec) or engine code. Some 1.9 TDI PD engines don't show the injection pump been driven of the timing belt. The Passat (88-96) 1,9D TDI 1993-96 Engine code: 1Z does and there is a locating pin in the IP pump pulley VAG No.2064 which is probably just a 6mm or 8mm parallel pin. A Camshaft setting bar - VAG No.2065A.
There will be a write up on here for timing belts changes try a search?
Discussion Starter #8
It's a 1Z engine. Also there is a DIY about timing belt change, but nothing on fuel pump adjustment.
Also I tried to locate the hole where sprocket is inserted, but it's not there. Can injection be so much off?
Yes that position is correct but is that someone else's picture?
Timing the pump is different to timing the pump to the belt.
You still haven't added the year to your car spec Wheeler97?
Yes, that's the picture from the 1Z/AHU engine writeup here.
If you have a 1Z engine, I assure you that the hole is there. Put the engine to TDC and you should see it, maybe you are looking at a dirt smudge on the flywheel instead of the correct stamp mark?
You can only move the injection pump a little bit. There is something on fuel pump adjustment, it's at the end of the writuep.
Discussion Starter #11
Well, everything is fixed. Timing belt has skipped and that was the problem.I think it must have happened on startup.
1 - 11 of 11 Posts
