Hello,
I have a 2014 Passat TDI, i had codes for the EGR and DPF so recently changed EGR Valve and had DPF professionally cleaned, after the changes i want to reset the Check Engine Light and the DPF light and Glow Plug blinking light and have no success of resetting it, any input and help why this cannot be done using VAG?
I do not have power on the car and that is why I performed these repair and want to reset the light.
Any input why these cannot be reset, is till have the power issue, is my car in Lump Mode?
take off both battery cables and zip tie them touching together for 30 minutes it should clear all codes and reset.
As I've already posted.
Myturbodiesel moving on
Release Notes
You don't need to do that for 30 minutes just a few seconds to discharge any capacitors in the system, that is an old trick that doesn't always work.
