in the morning it starts well and I leave after 300m. starts to shake works on the 3-cylinder it is for about a minute does it sometimes from 20 to 40 g or from 30-40 g of the engine then no problem does not do it every day or if it does when it's colder I've noticed.Nozzles and wiring in the head have been replaced,I tried with crazy rate sensors flow meter.it does it again, only when I remove the map sensor then there is no problem
8598
8600
Welcome to the forum.
That is a bit much for an intro.
Current VCDS Release
You can join Ross-Tech forum providing is a genuine cable that is registered as there are more experts on there. Post a full AutoScan in a new thread with your problem and pictures.
Ross Tech VCDS forum
