1 - 1 of 1 Posts
GTI 35 Edition , GTD Mk6, Jetta Mk5 BKD 2007
Hi there ,
My Passat lost all the sensors, reverse camera, audio steering controls, Bluetooth, telephone. I can see the Can Gateway unit is defective.
My radar, lane assist, radio still operate. Radio, navigation works fine, not sure how to treat this error.
I have installed a new Can Bus Module. Recorded in the same listing as old.
On that note my current coding: 462007
This seems to be a very shortcode. Seems not all control modules are registered, but present in the listed view inside Gateway.
I have installed a new Gateway with exact same numbers and list from the previous installation, just to get a Defective message again and not correctly coded. How can a new part say defective? Now, otyer errors are showing. please refer to below. Any help below is appreciated.
Quick Update, after removing all the modules, Media unit, Bluetooth, amplifier. etc. Same defective error. Was under the impression one of those is triggering the error.
Checked all the wiring continuity and all connector pins on the GW connector socket and Bluetooth media connector. I'm still in the same place when I started. Two gateways new and old ( coded same ) coming up with the same error.
Even tough gateway marks the addresses below as unreachable (media player, radio, sound system, navigation, all work independently). The camera, phone don't work.
Who on the forum has the V6 Alltrack model? VW has gone out of the way to move the battery. modules all over the place due to V6 placement.
What would belong coding?
I might not be seeing something here. Thanks in advance.
Please any detailed assistance would be appreciated.
Thursday,01,April,2021,22:19:15:41771
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 20.4.0.1 (x64)
Data version: 20200331 DS317.0
www.Ross-Tech.com
VIN: WVWZZZ3CZEE048825 License Plate: ALLTRACK
Mileage: 140090km-87047mi Repair Order: GWscan3
Chassis Type: 3C-VW46 (7N0)
Scan: 01 02 03 08 09 10 14 15 16 17 19 22 25 2E 36 37 3C 42 44 46
47 4C 4F 52 53 55 56 61 62 6C 6D 72 77 A5
VIN: WVWZZZ3CZEE048825 Mileage: 140090km-87047miles
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
10-Park/Steer Assist -- Status: OK 0000
14-Susp. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
19-CAN Gateway -- Status: Malfunction 0010
22-AWD -- Status: OK 0000
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
3C-Lane Change -- Status: OK 0000
47-Sound System -- Status: OK 0000
4C-Tire Pressure II -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
6D-Trunk Elect. -- Status: OK 0000
A5-Frt Sens. Drv. Assist -- Status: OK 0000
Address 01: Engine (0-32-BWS ) Labels:. 03H-907-309-V1.clb
Part No SW: 03H 906 023 L HW: 03H 907 309 A
Component: 3,6 FSI EU5 H04 2758
Revision: MFH04--- Serial number: 00000000000000
Coding: 001D0012242600000000
Shop #: WSC 00015 115 00000
ASAM Dataset: EV_ECM36FSI01103H906023L 002011
ROD: EV_ECM36FSI01103H906023L.rod
VCID: 2B55348C42A61BDE87-807E
No fault code found.
Readiness: 1110 0101
Address 02: Auto Trans Labels: 02E-927-770.clb
Part No SW: 02E 300 016 A HW: 02E 927 770 AL
Component: GSG DSG AG6 521 4001
Revision: 05652104 Serial number: 00001308061351
Coding: 0000020
Shop #: WSC 05311 000 00000
VCID: 122B89680DCCAA16A4-8046
Address 03: ABS Brakes Labels: 3AA-614-109.clb
Part No SW: 3AA 614 109 AQ HW: 3AA 614 109 AQ
Component: J104 C2 450M VDDC 0030
Revision: --H07--- Serial number: 00000007378600
Coding: 0001956
VCID: 7CF7C7D03F484C665E-8028
Address 08: Auto HVAC (J255) Labels:| 5K0-907-044.clb
Part No SW: 3AA 907 044 BB HW: 3AA 907 044 BB
Component: Climatronic H03 0404
Revision: 00001K01
Coding: 061401A002
ASAM Dataset: EV_Climatronic A01010
ROD: EV_ClimaAutoBasis_VW46.rod
VCID: 71E9E6E4A00A310EFD-8024
Address 09: Cent. Elect. (J519) Labels:. 3AA-937-087.clb
Part No SW: 3AA 937 087 Q HW: 3AA 937 087 Q
Component: BCM PQ47 H+ 422 0474
Revision: BC422001
Coding: 0008000000000000009C02805400297423D54B88666D8D60E48046240041
VCID: 489F6B00FB10D0C68A-801C
Subsystem 1 - Part No: 3AC 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 07081 26 0612
Coding: 00B795
Subsystem 2 - Part No: 1K0 955 559 AH Labels: 1K0-955-559-AG.CLB
Component: RLS 260813 05 54 0403
Coding: 0230ED
Address 10: Park/Steer Assist (J791) Labels:| 3AA-919-475.clb
Part No SW: 3AA 919 475 L HW: 4H0 919 475 E
Component: PARKHILFE PLA H06 0025
Revision: -------- Serial number: 56231322601587
Coding: 349106
Shop #: WSC 99999 1023 2097151
ASAM Dataset: EV_EPHVA2C000000000 002008
ROD: EV_EPHVA2C000000000.rod
VCID: 44877F30CF38F4A666-8010
Address 14: Susp. Elect. (J250) Labels:. 3C0-907-376.clb
Part No SW: 3C0 907 376 A HW: 3C0 907 376
Component: DAEMPFUNGS-SG H07 0071
Revision: 00000000 Serial number: 07081300990002
Coding: 010180
Shop #: WSC 05314 000 00000
VCID: 275DC8BC564E3FBE63-8072
Address 15: Airbags Labels: 5N0-959-655.lbl
Part No SW: 5N0 959 655 AE HW: 5N0 959 655 AE
Component: J234__106 VW10 HI 2318
Revision: 27019000 Serial number: 003N5PH5E7S+
Coding: 0012342
VCID: 000FB32053A0288602-8054
Subsystem 1 - Serial number: 6332MTS602982153
Subsystem 2 - Serial number: 6342MTS627212013
Subsystem 3 - Serial number: 6351HTS6I3M08CKR
Subsystem 4 - Serial number: 6361HTS613MF6CKR
Subsystem 5 - Serial number: 00000000000000000
Subsystem 6 - Serial number: 00000000000000000
Address 16: Steering wheel (J527) Labels:| 3C0-953-569.clb
Part No SW: 3C9 953 501 BL HW: 5K0 953 569 T
Component: LENKS.MODUL 016 0140
Revision: FF010042 Serial number: 20130823200420
Coding: 399A250001
ASAM Dataset: EV_VW360SteerWheelUDS A03004
ROD: EV_VW360SteerWheelUDS.rod
VCID: 74E7EFF0DF18042616-8020
Multifunction steering wheel control module:
Subsystem 1 - Part No SW: 3C8 959 537 D HW: 3C8 959 537 D Labels: 3C8-959-537.CLB
Component: E221__MFL-TK6 H07 0022
Coding: E30000
Address 17: Instruments (J285) Labels:| 3C8-920-xxx-17.clb-SRI1
Part No SW: 3AA 920 870 N HW: 3AA 920 870 N
Component: KOMBI H04 0811
Coding: 761F01
Shop #: WSC 05314 115 00000
ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04721
ROD: EV_Kombi_UDS_VDD_RM09_004_VW46.rod
VCID: 3D710AD4ACD2856E29-8068
1 Fault Found:
13654544 - Databus
U1121 00 [009] - Missing Message
[New feature! Extended UDS fault detail is only supported by current gen. interfaces]
Confirmed - Tested Since Memory Clear
Freeze Frame:
Fault Status: 00000001
Fault Priority: 6
Fault Frequency: 1
Reset counter: 220
Mileage: 140097 km
Date: 2021.04.01
Time: 13:08:17
Address 19: CAN Gateway (J533) Labels:. 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 AN HW: 7N0 907 530 AN
Component: J533 Gateway H56 1642
Revision: H56 Serial number: 070813F1003780
Coding: 462007
Shop #: WSC 05314 123 12345
VCID: 7CF7C7D0FF484C665E-8028
1 Fault Found:
01305 - Databus for Infotainment
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 1
Reset counter: 255
Mileage: 140097 km
Time Indication: 0
Date: 2015.08.23
Time: 13:08:20
Address 22: AWD Labels: 0AY-907-554-V1.clb
Part No SW: 0BS 907 554 C HW: 0BS 907 554 C
Component: Haldex 4Motion 4016
Coding: 0000005
Shop #: WSC 00000 000 00000
VCID: 468365383104C6B678-8012
Address 25: Immobilizer Labels: 3C0-959-433-25.clb
Part No SW: 3AA 959 799 C HW: 3AA 959 799 C
Component: IMMO 090 0407
Revision: 00090000 Serial number: VWZCZ000000000
Shop #: WSC 13171 001 1048576
VCID: 489F6B003B10D0C68A-801C
Subsystem 1 - Part No: 3C0 905 861 J
Component: ELV 029 0380
3C0905861J ELV 029 0380
Address 2E: Media Player 3
Cannot be reached
Address 36: Seat Mem. Drvr (J810) Labels: 3C0-959-760.lbl
Part No SW: 3C8 959 760 E HW: 3C8 959 760 E
Component: Sitzmemory H05 3001
Revision: 00H05000
Coding: 000039
Shop #: WSC 40022 666 40022
VCID: 377D18FC86EEAF3EF3-8062
Address 37: Navigation
Cannot be reached
Address 3C: Lane Change Labels: None
Part No SW: 3AA 907 566 C HW: 4G0 907 566
Component: J769 SWA MasterH02 0010
Revision: 00H02000 Serial number: 6PZ 010 316-09
Coding: 0001172
VCID: 39791EC470FAB94E05-806C
Subsystem 1 - Part No: 3AA 907 568 C
Component: J0770_SWA_Slave_H02 0010
Subsystem 2 - Serial number: 6PZ 010 316-29
Subsystem 3 - Serial number: 5F12.08.1300H02000AMS16392ÿ
Subsystem 4 - Serial number: S16392ÿ
Address 42: Door Elect, Driver (J386) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 701 A HW: 3C0 959 793 C
Component: TUER-SG FT 002 0534
Revision: 12110009 Serial number: 0007418446
Coding: 0013B7
Shop #: WSC 05311 115 00000
ASAM Dataset: EV_TSGFPQ35BRFVW46X A04001
ROD: EV_TSGFPQ35BRFVW46X_VW32.rod
VCID: 356112F494E25D2EE1-8060
Slave Driver:
Subsystem 1 - Part No SW: 3AA 959 704 A HW: 3AA 959 794 Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 004 0503
Serial number: 00000003615439
Coding: 010290
Address 44: Steering Assist Labels: 1K0-909-14x-GEN3.clb
Part No: 1K0 909 144 R
Component: EPS_ZFLS Kl. 209 3501
Revision: 00H22000
Shop #: WSC 02069 000 90108
Address 46: Central Conv. Labels:. 3C0-959-799-46.clb
Component: 02 KESSY PQ47 090 0367
Coding: 01900A00D2C30E76340494157200DFCE105800130427BC
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H05 1501
Subsystem 2 - Part No: 3C0 951 171 C
Component: Neigungssensor 004 0611
Subsystem 3 - Part No: 3C0 951 171 C
Component: Innenraumueberw.004 0611
Subsystem 4 - Part No: 3AA 962 243 B
Component: GEB.F.Heckoef 0810
Address 47: Sound System
Cannot be reached
Address 4F: Centr. Electr. II (J520) Labels:. 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 7N0 907 530 AN
Component: EZE_2 H56 1642
Coding: 00000008
VCID: 6FEDE09CBE3E27FEEB-803A
Subsystem 1 - Part No SW: 3AA 919 204 A HW: 3AA 919 204 A
Component: Analoguhr 004 0004
Address 52: Door Elect, Pass. (J387) Labels:| 3C0-959-70X-GEN4.clb
Part No SW: 3AA 959 702 A HW: 3C0 959 792 C
Component: TUER-SG BT 002 0534
Revision: 14110009 Serial number: 0007341678
Coding: 0013B6
ASAM Dataset: EV_TSGBPQ35BRFVW46X A04001
ROD: EV_TSGBPQ35BRFVW46X_VW32.rod
VCID: 366315F889E45636E8-8062
Slave Passenger:
Subsystem 1 - Part No SW: 3AA 959 703 A HW: 3AA 959 795 Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 004 0503
Serial number: 00000003613532
Coding: 010290
Address 53: Parking Brake Labels: 3AA-907-801.clb
Part No SW: 3AA 907 801 H HW: 3AA 907 801 H
Component: J540 EPB4 VW-86594 0010
Revision: H19 Serial number: 00000001376129
Coding: 0022157
VCID: 366315F841E45636E8-8062
Address 55: Headlight Range (J745) Labels:. 5M0-907-357-V3.clb
Part No SW: 5M0 907 357 F HW: 7L6 907 357 C
Component: AFS-ECU H04 0111
Revision: -------- Serial number: --------------
Coding: 023E00000B000200
ASAM Dataset: EV_HeadlRegulVWAFSPt 002016
ROD: EV_HeadlRegulVWAFSPt_VW46.rod
VCID: 377D18FC8EEEAF3EF3-8062
Subsystem 1 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo links H05 0012
Coding: 230000
Subsystem 2 - Part No SW: 3D0 941 329 B HW: 3D0 941 329 B Labels: 3D0-941-329.CLB
Component: LeiMo rechts H05 0012
Coding: 230000
Address 56: Radio
Cannot be reached
Address 61: Battery Regul. (J840) Labels:. 1K0-907-534.clb
Part No SW: 7N0 907 534 HW: 7N0 907 530 AN
Component: Batt.regelung H56 1642
Coding: 33261172
VCID: 71E9E6E4A80A310EFD-8024
Subsystem 1 - Part No SW: 3AA 915 181 A HW: 3AA 915 181 A
Component: J367-BDM H08 0181
Serial number: 60201658382211791672
Address 6C: Back-up Cam.
Cannot be reached
Address 6D: Trunk Elect. Labels: None
Part No SW: 3AF 827 383 A HW: 3AF 827 383 A
Component: J605 HECKDECKEL 0860
Revision: 00H52001
VCID: 3A7B01C875FCB2560C-806E
Subsystem 1 - Part No: 3AF 827 384 A
Component: J756 HECKDECKEL 0860
Subsystem 2 - Serial number: 1300H52001001C0293ÿ
Address 77: Telephone
Cannot be reached
Address A5: Frt Sens. Drv. Assist (R242) Labels:| 3AA-980-654.clb
Part No SW: 3AA 980 654 D HW: 3AA 980 654 A
Component: MFK_Gen1 H09 0300
Serial number: 0194035114
Coding: 010000000102020D0200000000010100
ASAM Dataset: EV_47X 001639
ROD: EV_47X.rod
VCID: 39791EC4B8FAB94E05-806C
End-------------------------(Elapsed Time: 04:20)--------------------------
1 - 1 of 1 Posts
