having sorted out a duff fuel temp sensor later in the day car starts to rock at tickover so removed oil cap and
i have vcds lite unregistered in measuring blocks group 4 i read
882 rpm 1.3 btdc 0.9btdc
1176rpm 0.4 atdc 0.4 atdc
do u think timing is out
or are piston rings shot
i always thought engines reqd more advance the faster they ran
seems a little odd
thoughts please hopefully not the scrap yard
tia
Car: Passat is a bit vague, you need to add the year?
Manufacturer: VW, Date(s) Used: 03/1996-12/1996, Model: Passat/Variant/4Motion, Engine Code: AFN, 81Kw, 110PS, 1.9 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection (TDI) Timing belt
Post moved to correct section. ;)
ah right well i am quite a fan passat wise ,,update i did compression test 380 on 3 cyl 160 on 1 other ,,,suspect stuck rings or even broken rings now ,,,trying to use water injection to decarbonise engine ,, might take some time though ,,how easy to remove sump and cyl head re ring the thing ,,tempting
Banned
Same-same here. I use a cassette style demagnetiser which has always done the job nicely but, from what Ive read in you post, would it be right to suggest a demagnetising wand would also be needed to demagnetise the capstan?
