1 - 14 of 14 Posts
Hi.
So I have a problem with 1.9tdi pd engine passat, engine code AVB. Help is really appreciated if anyone knows what can be wrong before changing tandem pump or injector seals to find out problem is somewhere else.
Problem: Starts fine if shut down from key. Idles fine for about 10mins after start and then starts to shake and injection quantity deviation is maxed out at 2.99. No fault codes. Looks like the car is running out of fuel and when fuel return line from tandem pump is clamped idling goes normal again. Clamp out and car dies. No smoke from exhaust when running and only does this after 10minutes idling or driving. Engine runs fine when pressing throttle but doesn't stay at idle after the problem starts.
Glow plug light comes on for few seconds when ignition on and lift pump pumps fuel too.
After stalling motor is unable to start until next day, except one time it started while cranking with clamped return line.
Thanks for the help.
The tandem pump has a fuel pressure regulator that fails. Look it up and see how to replace it.
Something like this is what I'm finding
One for a 2013, not sure about you're specifically
His is a PD and not a CR. Would really need to scan it with VCDS to know what is going on
Discussion Starter · #4 ·
Scan with vcds done a few times but no faults stored. Measure group 013 shows that injector deviation goes 2.99mg/str in 2 cylinders and 2 at -2.99mg/str when problem starts, first ten minutes of running these values are nicely within spec at less than +-0.5mg/str.
Theres a fuel return valve on tandem pump which should keep pressure at 14-15psi so obviously its not working or pressure is leaking somewhere else because when return line is pressed together engine starts to run normally almost instantly.
I think you should put a new one in. Not sure if it's the one I posted before, I just searched for the engine and pressure regulator. Fuel return valve as you call it is what I read talking about in the first place and searching have me the results I found before.
Do you know what the one you have looks like? Is it like this Genuine VW/Audi VW-06D130757C Fuel Pressure Regulator; Inline Restrictor SKU: 1433187-VW-06D130757C - Audi, VW | 06D130757C
This is a decent little video on a 2004 Jetta, different car but a PD. Test should be similar. I lean towards the return valve either way, however, it could be two fold.
Sent from my moto g(7) power using Tapatalk
Discussion Starter · #7 ·
Im talking about this valve which is built in tandem pump as shown in this picture.
8472
Here's a post on one
So the rebuild kits I've seen should have two springs for the inlet and return valves. Those springs wear and fail causing the valve to let to much fuel through. I haven't been able to find a valve, so I assume that you simply need to rebuild it, or replace the pump. Rebuild is much cheaper. I think the pressure test could be effected by the springs being worn and not holding pressure giving a false reading of the lift pump.
Also I ordered a URO lift pump from fcp euro I think it was, for around $100...
Waking up this threat.
I have similar problem.
The pump in tank is changed, I have also tested an other tandem pump, with the exact same results. Car still dies after about 10 minute drive and starts sometimes 1-3 days after.
This is what I have asked in other groups:
Hi
Im trying to get a Golf V 2007 1.9Tdi to start. It died intermittent during drive - but now it wont even start.
There are no fault codes.
Suspecting it could perhaps be the check valve in the lid on the fuel filter holder.
They are not easy to find here - so Id like to find a picture on a working check valve to compare with. Any one have one, they could take a picture of (the inside of the filter holder)?
It has this number: 1K0127400K
And it is the type A.
Link on Amazon:
The day after:
I have ordered a used fuel filter holder.
I can fill the fuel filter cup with fuel, with 12V directly on pump. Still couldnt start the engine yesterday.
Today I wanted to be sure the timing was correct and was ready to read measuring blocks during crank - when the bloody engine started!
Pump in tank went on when I turned ignition on, then engine started.
So I run inside to get low amp probe and SnapOn - the tank pump was not running!
I took off the electric connector on tank pump and the engine continued to run.
I turned off the engine. Started it again, without tank pump connected.
The fuel filter holder will be run empty by the tandem pump.
Am I thinking correct here:
There must be a pressure switch in the fuel pump in the tank - that switches off when the fuel pressure is up in the fuel filter holder.
If a check valve in the filter holder lid is stuck closed - the pump in the tank will not turn on (its brand new).
But I cannot find ANY information on the check valve on a fuel filter holder modell A, where the valve is placed within the lid construction (and not the separate type placed above the lid, that can be changed separately).
Here is a Autoscan - with a fault code from me disconnecting the electric connector:
Code:
Monday,16,November,2020,14:00:32:18201
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64
VCDS Version: 20.4.2.0 (x64)  HEX-V2 CB: 0.4513.4
Data version: 20200730 DS317.0
www.Ross-Tech.com
Dealer/Shop Name: Firma Johannes Bruun
Workshop Code: 000 02013 000000
VIN: WVWZZZ1KZ7W264681   License Plate: BWH469
Mileage: 263050km-163451mi   Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56
VIN: WVWZZZ1KZ7W264681   Mileage: 263050km-163451miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
15-Airbags -- Status: OK 0000
17-Instruments -- Status: Malfunction 0010
56-Radio -- Status: Malfunction 0010
Address 01: Engine        Labels: 03G-906-016-BKC.clb
   Part No SW: 03G 906 021 KG    HW: 03G 906 021 AN
   Component: R4 1,9L EDC  000SG  9244
   Revision: --H07---    Serial number: VWZ7Z0G8112637
   Coding: 0000071
   Shop #: WSC 01392 785 00200
   VCID: 6E85CCE2FC9374EBB0F-803A
No fault code found.
Readiness: 0 0 0 0 1
Address 03: ABS Brakes        Labels: 1K0-907-379-MK70.lbl
   Part No: 1K0 907 379 P
   Component: ASR FRONT MK70      0105
   Coding: 0017025
   VCID: 3FDB41A6EB79CD636B9-806A
Address 08: Auto HVAC        Labels: 1K0-820-047.lbl
   Part No SW: 1K0 820 047 FT    HW: 1K0 820 047 FT
   Component: Climatic PQ35   141 0909
   Revision: 00141027    Serial number: 00000000000000
   Shop #: WSC 00000 000 00000
   VCID: 7BA3F5B6BFE11143071-802E
Address 09: Cent. Elect.        Labels:. 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 AD    HW: 3C0 937 049 AD
   Component: Bordnetz-SG     H52 2002
   Revision: 00H52000    Serial number: 00000006938468
   Coding: 08890F2700041500471400001400000000097B075C0001
   Shop #: WSC 00000 785 00200
   VCID: 6B83C5F6CF8181C3971-803E
   Subsystem 1 - Part No: 1K1 955 119 E  Labels: 1KX-955-119.CLB
   Component: Wischer 180407 021  0501
   Coding: 00038805
   Shop #: WSC 00000
Address 15: Airbags        Labels: 1K0-909-605.lbl
   Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
   Component: 37 AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD15ZV80
   Coding: 0013111
   Shop #: WSC 01373 785 00200
   VCID: 3D273BAEE175DF73795-8068
   Subsystem 1 - Serial number: 6332MSME177E4B65Q
   Subsystem 2 - Serial number: 6342MSME17101C600
   Subsystem 3 - Serial number: 6352QSME246D2369M
   Subsystem 4 - Serial number: 6362QSME26724D7FY
Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
   Part No SW: 1K0 953 549 BB    HW: 1K0 953 549 BB
   Component: Lenksäulenmodul 036 0070
   Coding: 0000002
   Shop #: WSC 00011 768 00200
   VCID: 73B3DD9697B159035F1-8026
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No SW: 1K0 920 853 Q    HW: 1K0 920 853 Q
   Component: KOMBIINSTRUMENT VDD 1610
   Revision: V0003000    Serial number: VWZ7Z0G8112637
   Coding: 0003103
   Shop #: WSC 02013 222 99650
   VCID: 38292ABACE57FA5BAA3-806C
1 Fault Found:
00771 - Fuel Level Sensor (G)
            010 - Open or Short to Plus - Intermittent
             Freeze Frame:
                    Fault Status: 00101010
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 75
                    Mileage: 263053 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:47:05
Address 19: CAN Gateway        Labels:. 1K0-907-530-V2.clb
   Part No SW: 1K0 907 530 K    HW: 1K0 907 951
   Component: J533__Gateway   H04 0021
   Revision:   H04 02    Serial number: 080407F1001349
   Coding: 3D0F034007000002
   VCID: 2F3B11E63B193DE3FB9-807A
Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
   Component: IMMO            VDD 1610
Address 42: Door Elect, Driver        Labels:. 1K0-959-701-MIN3.clb
   Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
   Component: Tuer-SG         005 0987
   Coding: 0000180
Address 44: Steering Assist        Labels: 1Kx-909-144-G2V3.clb
   Part No: 1K1 909 144 L
   Component: EPS_ZFLS Kl.069 H07 1806
   Shop #: WSC 00000 028 00001
   VCID: 34311E8AD23F1E3B86B-8060
Address 46: Central Conv.        Labels:. 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CP
   Component:    KSG              0401
   Coding: 81C802087F2D8405484BC6F010CC
   Shop #: WSC 40950 222 21286
   VCID: 0059825AD607729B523-8054
   Subsystem 1 - Part No: 1K0 951 605 C
   Component: LIN BACKUP HORN H03 1301
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
Address 52: Door Elect, Pass.        Labels:. 1K0-959-702-MIN3.clb
   Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
   Coding: 0000180
   VCID: 392F2FBEF55DE35355D-806C
Address 56: Radio        Labels: 1K0-035-1xx-56.lbl
   Part No SW: 1K0 035 186 T    HW: 1K0 035 186 T
   Component: Radio BVX       034 0046
   Revision: 00034000    Serial number: VWZ1Z2G4739028
   Coding: 0020200
   VCID: 372B2986C349F523A39-8062
1 Fault Found:
01044 - Control Module Incorrectly Coded
            000 - -
End----------(Elapsed Time: 01:03, VBatt start/end: 12.6V/12.4V)-----------
There's a fuel pressure regulator you need to check. First check the fuel pressure to the rail at the tandem pump.
You should always start a new thread and link the thread you find with information related to yours. However, I'm not sure the above thread will help you much.
Hi
Link on Amazon:
The day after:
Code:
www.Ross-Tech.com
   Coding: 0000071
   Coding: 0017025
   Coding: 00038805
   Shop #: WSC 00000
   Coding: 0013111
   Coding: 0000002
   Coding: 0003103
1 Fault Found:
             Freeze Frame:
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 75
                    Mileage: 263053 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 13:47:05
   Coding: 0000180
   Component:    KSG              0401
   Coding: 0000180
   Coding: 0020200
1 Fault Found:
            000 - -
Hi, did you finally get this issue sorted? I have an almost identical issue with a mk5 golf 1.9tdi
1 - 14 of 14 Posts
