So, I installed a MFSW today on my '09 JSW after consulting the how-to FAQ on this site and VWVortex. The good news is that it's coded and works perfectly (I had to replace the control module and airbag harness, but that's another story).
The bad news is that after reconnecting the battery, I can't get the sunroof to close. I left it in the tilt position while I was working on the car. Naturally it was in this position when I reconnected the battery.
I've started and stopped the motor, let it sit for a while, and driven around town but it still doesn't work. The sunshade works perfectly.
I could take it to the dealer but since I'm the one who fiddled around with the car it probably won't be covered under the warranty.
Anyone have a clue on how to fix it, or at least tilt it back down? I looked in the owner's manual and, surprise, it is useless! There are no directions on how to manually close the roof.
I can't figure out where the motor is. I thought it might be under the switch and headliner up front but after taking that area apart I think I found nothing more than the control module.
Here's the fault code I get:
Address 4F: Central Electr. II (J533)
[then some gobbly **** about part numbers and serial codes, I'm copying this from a PC to Mac on the internet]
01512 - Control Module for Sliding Roog
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 2
Fault Frequency: 1
Reset Counter: 137
Mileage: 20875 km
Time indication: 0
Date: 2000:00:00
Time: 00:00:17
I would love to fix this before it rains. Any suggestions?! :dunno
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset Counter: 137
Mileage: 20875 km
Time indication: 0
Date: 2000:00:00
Time: 00:00:17
