1 - 13 of 13 Posts
Hey guys after extensive reading. cleaning and cussing I still cannot figure out why I have an intermittent CEL.
I have a 2004 Golf TDI PD with 185k miles. One day I was coasting down the highway and noticed that I had a CEL come on. I pulled over immediately checked all my fluids and everything seemed safe to continue driving. I made my way to the closest Autozone and tried reading the code, but as soon as I plugged the reader in, the CEL went away. About a week later it came back on. The code reader pulled P2413 EGR system performance. 1. Faulty EGR valve or 2. Blocked EGR passages. I thought this would be an easy win. I bought some cleaner and went home to remove the EGR. It was COVERED in carbon build up. Cleaned it all up and re-installed. That day the car ran like absolute garbage. (previously had no performance issues). The next morning I pulled the EGR and IMF (intake manifold flap) both off and cleaned them thoroughly. The CEL went off and performance returned to normal. 3 days later the light came back on! At this point I have become frustrated and just decided to drive it because its not having any performance issues. After 2 hours of DoorDash the light goes off... The next morning upon start up the light comes back on. So back to Autozone I went. I bought more cleaner and a MAF sensor cleaner. Cleaned all parts to perfection and re assembled. I drove the car to Autozone and reset the CEL. Performance was perfect and no engine lights. This morning the CEL came back on and throttle response was affected almost as the engine was stalling only intermittently. So...
Is the IMF only a 2 position valve? (aka no variation other than open or closed)
How does the ECU measure EGR performance? MAF or sensor position?
I have checked for boost leaks, and found none.
My IMF will partially close while pressing the throttle, is this normal?
I have attached pictures of my EGR and a video of the current function of the IMF. Remember both of these components are electronically controlled unlike the vacuum controlled components of the years prior.
Discussion Starter #2
Please call me or text me if you have any questions/advice 817-673-7354
Myturbodiesel moving on
Release Notes
VAG Error Code: 009235/18895
EOBD II Error Code: P2413
Fault Location:
Exhaust Gas Recirculation (EGR) System - Performance Malfunction
Possible Cause:
Hoses blocked/leaking.
Exhaust Gas Recirculation (EGR) solenoid.
Exhaust Gas Recirculation (EGR) valve.
Possible Solutions:
Check hoses/connections.
Number of learning points at fuel mass adaptation limit > or = to 4. At upper limit = 6 mg/stroke. At lower limit = -6 mg/stroke.
That DIY is not for the PD engines. You probably have a BRM or BEW. Look around YouTube for how-tos. View a few of them before you dig in; some are better than others.
Discussion Starter #6
Thanks to all that have replied so far!
Since the above post, I took the car on a small 250 mile road trip and on the way there the car went into complete limp mode, I would call it. Zero turbo spool, and no boost lead to a slow car barely able to reach 70 mph.
There was a blown fuse at F34 or which controls the throttle body and a couple other systems. Replaced the fuse and it was back on the road with boost, but still a CEL.
I replaced the throttle body(IMF or ASV whatever) with a new one, but still had the codes!
Drove the car another 100 miles without performance issues other than shuddering when turning the engine off. (A feature of the throttle body) and with th engine codes as follows:
P2102, P2108 along with the P2413 I had originally.
This morning I looked closely for electrical issues and found this. Resized_20201016_074834.jpeg
With a short amount of time this morning I picked up a new connector from VW (that didn't come with terminals or the rubber isolators) I ran out of time to replace the connection. I took electrical tape and isolated the broken wires from each other and reconnected everything. Now I only have the code P2413...
The plan is to rebuild this connection when time allows and fingers crossed it will take care of the EGR code on its own.
Any advice/criticism is wanted!
Travis
Discussion Starter #7
KeithUK thank you for your reply.
My EGR is electronically controlled I have removed it and cleaned it thoroughly. What other hoses/connections do you recommend I clean or inspect? All of the intercooler and turbo lines appear to be intact.
Discussion Starter #9
David thank you! I did purchase a cheap OBD2 scanner in the process of all this. The VCDS system seems so nice! I will have to get one soon! But for now the $35 one I'm using will have to do until I can purchase the $200 VCDS.
Discussion Starter #11
I will definitely look around some more! Thanks! I will update when I can.
VW Jetta TDI Mk5 2005.5 BRM
As @PeterAFox mentioned, your intake manifold is likely carboned up as well. My first Mk4 had that issue, it didn't cause me a CEL, but it took me about 60 seconds to go zero to sixty, so I'd suggest taking a look at that as well (though it won't solve your CEL).
Discussion Starter #13
So here's the latest update. The connection at the throttle body was shorting out due to bad wires which fried the throttle body. I replaced the throttle body and connectors and all codes are gone except the P2413 EGR system performance. I have looked over all the hoses and everything seems fine. I think I might replace the N75 valve next or check valve because this CEL is driving me crazy!
8699
8700
Let me know where I should check next. Remember this is a PD BEW engine.
1 - 13 of 13 Posts
