Hi all,
I replaced the DPF and EGR filter a couple of weeks ago in my 2011 Jetta TDI and shortly thereafter starting receiving a P0471 code concerning the sensor (directly behind the oil fill cap). I replaced that this weekend and idles and runs fine but as test driving it it will occasionally lose power and start stuttering. The only code it is throwing is the P240F now.
I monitored the EGR with VCDS while driving and noticed the EGR (actual) value would jump up right before it started doing the stuttering. (see pics below). I drew a blue line to show when the car was stuttering. It would only do this for a few moments then stop.
Any ideas how to troubleshoot this further?
Rectangle Slope Font Line Screenshot
Colorfulness Font Rectangle Screenshot Slope
Code:
Sunday,26,February,2023,18:54:05:44528
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 22.10.0.1 (x64)  HEX-V2 CB: 0.4623.4
Data version: 20221026 DS344.0
www.Ross-Tech.com
Dealer/Shop Name: Brad's Garage
VIN: 3VWLL7AJ3BMXXXXXX   License Plate:
Mileage: 327970km-203791mi   Repair Order:
Chassis Type: AJ-VW36 (6N0)
Scan: 01 02 03 08 09 15 17 19 25 2E 44 56 77
VIN: 3VWLL7AJ3BM025704   Mileage: 327970km-203791miles
02-Auto Trans -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
Address 01: Engine (CJA)       Labels: 03L-906-022-CBE.clb
   Part No SW: 03L 997 030 P    HW: 03L 906 019 DA
   Component: R4 2.0l TDI G000AG  9983
   Revision: 12H10---    Serial number:
   Coding: 0050078
   Shop #: WSC 64109 003 1048576
   VCID: 3B233A68BF6F7FD3FE0-806E
   VINID: 0E69DC70745A0D27400851C010418FA861
1 Fault Found:
009231 - Exhaust Gas Recirculation System
               P240F - 000 - Response too Slow
             Freeze Frame:
                    Fault Status: 01100000
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 255
                    Mileage: 327971 km
                    Time Indication: 0
                    Date: 2017.07.19
                    Time: 18:39:55
             Freeze Frame:
                    RPM: 1357 /min
                    Speed: 29.0 km/h
                    Load: 68.2 %
                    Mass Air / Rev.: 0.0 mg/str
                    Mass Air / Rev.: 70.0 mg/str
                    Mass Air / Rev.: 290.0 mg/str
                    Mass Air / Rev.: 435.0 mg/str
Readiness: 0 0 0 0 1
Address 02: Auto Trans        Labels: 02E-927-770.clb
   Part No SW: 02E 300 052 G    HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 9136
   Revision: 05151112    Serial number: 00001008130562
   Coding: 0000020
   Shop #: WSC 00066 000 00000
   VCID: 1869C5E4EE9974CB332-804C
1 Fault Found:
18149 - Clutch Pressure Adaptation
            P1741 - 002 - Limit Reached - Intermittent
             Freeze Frame:
                    Fault Status: 00100010
                    Fault Priority: 0
                    Fault Frequency: 255
                    Reset counter: 1
                    Mileage: 327919 km
                    Time Indication: 0
                    Date: 2017.07.19
                    Time: 20:59:37
Address 03: ABS Brakes (J104)       Labels:. 1K0-907-379-60EC1F.clb
   Part No SW: 1K0 907 379 BC    HW: 1K0 907 379 BC
   Component: ESP MK60EC1   H30 0106
   Revision: 00H30001
   Coding: B14B400C492400FF8D1202E4921D0042A70000
   VCID: 74B1D154DEB1F0ABFFA-8020
No fault code found.
Address 08: Auto HVAC        Labels: 5C0-820-047.clb
   Part No SW: 5C0 820 047 Q    HW: 5C0 820 047 Q
   Component: J301  Klimaanlage   0103
   Revision: 2000908S    Serial number: 00000000094257
   VCID: 2E05033C7C1D9A7B49E-807A
Address 09: Cent. Elect. (J519)       Labels:. 6R0-937-08x-09.clb
   Part No SW: 5C0 937 087 E    HW: 5C0 937 087 A
   Component: BCM25 JLB H3  H66 0257
   Revision: B2066001    Serial number: 03311286100308
   Coding: 7B994B9A08A30B0008382000240884C50082502E60000000300000000000
   Shop #: WSC 10123 002 1048576
   VCID: 2F3B1E3877179373428-807A
   Subsystem 1 - Part No SW: 6R0 959 801 M    HW: 6R0 959 801 M  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  002 3463
   Serial number: --------------------
   Coding: 820000
   Subsystem 2 - Part No SW: 6R0 959 802 P    HW: 6R0 959 802 P  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  002 3463
   Coding: 820000
   Subsystem 3 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.019  H08 0006
   Serial number:     WRH0000GZ2N
   Coding: 180000
   Subsystem 4 - Part No SW: 5K0 959 542     HW: 5K0 959 542
   Component: E221__MFL-TAS  H05 0010
   Serial number: 0138442
   Coding: 020000
   Subsystem 5 - Part No SW: 6R0 959 811 D    HW: 6R0 959 811 D
   Component: J388__TSG_HL  002 3463
   Coding: 800000
   Subsystem 6 - Part No SW: 6R0 959 812 D    HW: 6R0 959 812 D
   Component: J389__TSG_HR  002 3463
   Coding: 800000
1 Fault Found:
03444 - Ignition Starter Switch
            008 - Implausible Signal - Intermittent
             Freeze Frame:
                    Fault Status: 00101000
                    Fault Priority: 3
                    Fault Frequency: 2
                    Reset counter: 70
                    Mileage: 327482 km
                    Time Indication: 0
                    Date: 2017.07.19
                    Time: 15:43:44
Address 15: Airbags (J234)       Labels:| 5K0-959-655.clb
   Part No SW: 5C0 959 655     HW: 5C0 959 655
   Component: AirbagVW10G   012 0805
   Serial number: 003END0883SE
   Coding: 00003232
   ASAM Dataset: EV_AirbaVW10SMEVW360 A01017
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: 6FBBDE38B717D373028-803A
   Seat occupied recognition:
   Subsystem 1 - Part No SW: 5C6 959 339     HW: 5C6 959 339
   Component: BF-Gewichtss.  H10 0027
   Serial number: 6940000Y10000013740Q
   Coding: 303143
   Crash sensor for side airbag: driver side:
   Subsystem 2 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Fahr.V  H01 ----
   Serial number: 3572MSME616F7356ZZZ%
   Front Passenger's Side Airbag Crash Sensor:
   Subsystem 3 - Part No SW: 5K0 959 354     HW: 5K0 959 354
   Component: S.Sens.Beif.V  H01 ----
   Serial number: 3582MSME63684255ZZZX
   Rear Side Airbag Crash Sensor (on driver's side):
   Subsystem 4 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Fahr.H  H01 ----
   Serial number: 3516KSME031B060DZZZN
   Passenger side rear thorax airbag crash sensor:
   Subsystem 5 - Part No SW: 5K0 959 351 A    HW: 5K0 959 351 A
   Component: S.Sens.Beif.H  H01 ----
   Serial number: 3526KSME4749070DZZZY
   Crash sensor for front airbag: driver side:
   Subsystem 6 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Component: F.Sens.Fahr  H01 ----
   Serial number: 3556LSME5D201309ZZZR
   Crash sensor for front airbag: front passenger side:
   Subsystem 7 - Part No SW: 5K0 959 659 A    HW: 5K0 959 659 A
   Component: F.Sens.Beif  H01 ----
   Serial number: 3566LSME531F1509ZZZY
Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
   Part No SW: 5C6 920 950 E    HW: 5C6 920 950 E
   Component: KOMBI         H07 0406
   Serial number: 00000000000000
   Coding: 270A01
   Shop #: WSC 00066 000 00149
   ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04089
   ROD: EV_Kombi_UDS_VDD_RM09_004_VW36.rod
   VCID: 2C0109344681E86B67A-8078
Address 19: CAN Gateway (J533)       Labels:. 6N0-909-901-6R.clb
   Part No SW: 6N0 909 901     HW: 5C0 937 087 A
   Component: GW-K-CAN TP20 H66 0257
   Revision: B2066001
   Coding: 102200
   VCID: 70B9DD44AAA9CC8B1B2-8024
Address 25: Immobilizer (J334)       Labels:| 5K0-920-xxx-25.clb
   Part No SW: 5K0 953 234     HW: 5K0 953 234
   Component: IMMO          H07 0406
   Serial number:
   Coding: 000000
   Shop #: WSC 00000 000 00000
   ASAM Dataset: EV_Immo_UDS_VDD_RM09 A03008
   ROD: EV_Immo_UDS_VDD_RM09_VW21.rod
   VCID: 6A8DCF2C8CF5365B556-803E
Address 2E: Media Player 3 (J650)       Labels:. 5N0-035-342.lbl
   Part No SW: 5N0 035 342 C    HW: 5N0 035 342 C
   Component: SG EXT.PLAYER H13 0111
   Revision: A1001003    Serial number: 7668662932
   Coding: 010000
   VCID: 270BF6185FE7CB338A8-8072
Address 44: Steering Assist        Labels: 1K0-909-14x-GEN3.clb
   Part No: 1K0 909 144 J
   Component: EPS_ZFLS Kl. 70     3001
   Revision: 00H17000
   Shop #: WSC 02069 000 90108
   VCID: 313F18406D23858354C-8064
Address 56: Radio (J503)       Labels:. 5M0-035-1xx-56.clb
   Part No SW: 1K0 035 180 AC    HW: 1K0 035 180 AC
   Component: Radio Prem-8  H10 0045
   Revision: -----19S    Serial number: VWZ4Z7J3028815
   Coding: 0000000001
   Shop #: WSC 00066 123 12345
   VCID: 619FA8007143750384C-8034
1 Fault Found:
02635 - Tuner Not Enabled/Activated
            000 - -
             Freeze Frame:
                    Fault Priority: 7
                    Fault Frequency: 4
                    Reset counter: 36
                    Mileage: 315883 km
                    Time Indication: 0
                    Date: 2017.07.19
                    Time: 10:06:56
Address 77: Telephone (J412)       Labels:| 7P6-035-730.clb
   Part No SW: 7P6 035 730 C    HW: 7P6 035 730 C
   Component: TELEFON       H05 0440
   Revision: 1B001001    Serial number: 00007668436740
   Coding: 0A00000000010100
   Shop #: WSC 01383 790 50316
   ASAM Dataset: UHVNA A01007
   ROD: UHVNA.rod
   VCID: 323D174C64A5BE9B2D6-8066
End----(Elapsed Time: 01:25, VBatt start/end: 12.1V/12.0V. VIgn 12.0V)-----
Hi! Im new here.
I have a 2013 golf tdi-
even after the dealer replaced the valve flap-lagging out between 30-35 mph- i got used to driving in sport mode going through towns . helped for a while but now the DPF needs replacing and once again.......the valve flap - no longer under warranty so it's gonna be $$$$
