Hi All,
2004 Jetta TDI Wagon, 5 speed. New CEL that I am trying to figure out. At this time I have the VCDS print out of the error code and going from notes on the other data.
1) I have been getting the P2196 18628 Oxygen Sensor Signal too High (Rich)-Intermittent. (only DTC)
2) Put on the VCDS, with a cold engine at idle (78 Deg. F.) the MAF had a high specified and actual at idle (> 800 mg/str) and (>90% duty cycle). This had been in high end of normal range, but never this high. (I expected 300 - 400 mg/str at idle) This number came down in the 400 range when the engine warmed up.
3) When going down the road, the MAP actual was about 200 mbar higher than the spec. (they were closer last time I checked)
4) EGR was a high percent number, so EGR I expect to be closed. (100%=closed, 0%=open)
I wondered about the actuator on the turbo (higher than expected boost) so I put my vacuum gage on it at the N75 valve, stroke was good with a stroke of about 4 to 20 inHg. No vacuum leaks. Check all of the vacuum hoses and they are good.
MAF was new a VW part 2 years ago.
EGR valve was new about 2 years ago. Car runs GREAT! Been getting 42 to 46 mpg. Has Malone stage 1 tune.
Being an Intermittent HIGH signal would this be the sensor itself? I did not put my eyes on the O2 sensor, it must be hidden.
What other parameters should I be looking at?
I have the Liquid Moly Diesel Purge that I will run through this weekend and check the changes.
Thanks!
Thanks!
