I have a post in the introductions but I think here is more appropriate. Just got back from AutoZone had them do a scan...trouble code P1246 needle lift sensor circuit range performance...explanation open or short circuit condition...probable cause Check sensor resistance or replace #3 injector with needle lift sensor. I have done a visual check and wire looks OK...there has been a splice made in two wires that look to connect a hose/tube under the injectors going to the head. How do you get the sensor connector to release? I forgot to mention that at the plug I see that there are only two wires going in, a blue and a gray. But when I inspect further down about 2 inches peel back some electrical tape there is a black wire that terminates no where and looks to be cut...any insight? Thanks for any help
ukerofl
