I have a 2010 JSW with ~50k miles on it. This week the check engine light came on, and I hooked it up to a VAG-COM interface:
I did a quick drive and watched the RPM, MAF sensor values, and Engine load (bank 3). Initially the MAF requested matched the Actual and the Engine load seemed responsible. Roughly 30 seconds after I started the car the Engine load got pegged at 100% and the MAF actually tracked at roughly double the requested value. This seems like it is probably related to the exhaust pressure control valve being stuck open.
Are there any suggestions on possible solutions to fix this? Where is the valve located and is it possible to clean?
Thanks for your help, Ian
Address 01: Engine (CJA) Labels: 03L-906-022-CBE.clb
Part No SW: 03L 906 019 CL HW: 03L 906 022 TS
Component: R4 2,0L EDC G000SG 7274
Revision: 12H02--- Serial number:
Coding: 0050072
Shop #: WSC 08149 444 83815
VCID: 77F621197F4B
1 Fault Found:
001151 - Exhaust Pressure Control Valve: Stuck Open
P047F - 000 - - - MIL ON
Freeze Frame:
Fault Status: 11100000
Fault Priority: 2
Fault Frequency: 20
Mileage: 80700 km
Time Indication: 0
Date: 2018.14.06
Time: 15:19:48
Freeze Frame:
RPM: 2507 /min
Speed: 21.0 km/h
Load: 44.3 %
Load: 34.1 %
Lambda: 100.2 %
Temperature: 24.0°C
Temperature: 29.7°C
Readiness: 1 1 0 0 0
Coding: 0050072
VCID: 77F621197F4B
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 20
Mileage: 80700 km
Time Indication: 0
Date: 2018.14.06
Time: 15:19:48
Freeze Frame:
RPM: 2507 /min
Speed: 21.0 km/h
Load: 44.3 %
Load: 34.1 %
Lambda: 100.2 %
Temperature: 24.0°C
Temperature: 29.7°C
