hi all
car is passat tdi 2001, automatic 5speed 01v zf, AVF engine code
my car is loosing power every now and then
and u know to get the power back i have to switch off then on
so i hooked up the vag com cable, and it gave me this error
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
so i checked all the hoses that starts from EGR to the turbo
all was fine ,, i didnt check the vacuum hoses
i changed them all instead with silicon ones according to some
article i found on the net with the right diameter
still the problem exists.
a year ago i had the same problem but with "Negative Deviation"
at that time i got the turbo out and cleaned it well
and just i did get the turbo out, cleaned it
very well , checked the vanes, the actuator rod
all works fine and great
put everything back, drive test it, still problem exists
i noticed that this problem occures more when the car is cold
when its hot it works fine most the time, but it dies on me other times
i hooked up the vagcom cable again and took the car for a test
to make a log file in block 11 or group 11 whatever u call it
http://www.2shared.com/file/o11bIGEi/LOG-01-011-x44xx-xxx.html
what do you guys think the problem is ??
thanks all
thanks all
