Seeking suggestions for dealing with old oil that will not drain from a TDI that I am putting back into service after not being used for several years. I've looked on these forums and elsewhere online for discussions of this condition and have come up with nothing quite like this. Here are the details.
My 2010 VW Jetta Sportwagen TDI 2.0 (CBEA/CJAA engine) with automatic transmission has sat unused for 4 years. It ran fine prior to parking it. I am getting it ready to put back into use and am doing the initial work myself. I am an occasional do-it-myself maintenance person, but for most service I take my cars to a good local shop. My first objective is to get the car started without doing any harm.
My thinking is that before the first restart of the engine I ought to change the oil, change the battery, check the appearance and levels of the other fluids, search for and remove any debris (nests, leaves, etc.) in the engine compartment, siphon out the old fuel and put in fresh diesel, and lubricate the cylinder walls some how.
With the battery replaced, the engine compartment cleared of debris (no nests), and the air filter replaced, I moved on to the oil change, which is where I hit an unexpected snag. Less than half a cup (4 oz or about 120 ml) of oil flowed out of the oil pan drain hole.
Here are the oil change steps I've taken so far. First checking the oil level, the dip stick showed oil to be present but low--probably about a quart (liter) low. Next, I freed up the oil filter (3-foot lever arm required to loosen filter compartment cap). The filter had caked-on thick oil. I also opened the oil fill cap and saw that at the bottom of the filler neck is a film of thick, black oil. I unscrewed the drain plug with a basin in position to catch the oil, but no oil flowed out. Hoping a slug of thick oil might be right at the exit clogging the drain, I inserted a wire and wiggled it around, which did dislodge about 2 ounces (1/4 cup) of thick, black oil, but no more.
I am concerned that using an engine flush product with some new oil could cause problems, spreading the existing gunk around and clogging various small oil pathways. At the end of the flushing process, small particles may be left behind that could circulate and create future problems. With that concern, I could remove the oil pan and clean it and the exposed areas manually, including removing and cleaning the oil pick-up assembly. I'm guessing that would remove most of the oil and sludge.
Would that be adequate? Or, should other parts be exposed for cleaning too, such as removing the valve cover to clean all parts exposed there?
Given the gummy film present in the oil filler neck, I realize that the upper parts of the engine where oil can pool (no idea how numerous those might be) probably also have oil sludge too. Opening up the valve cover in this engine looks to be quite a bit more involved than removing the oil pan. If that is called for, I'll probably resign from this job and let my local shop take over.
Once I get this oil change addressed, I'd like to lubricate the cylinder walls. Could that be done by removing the glow plugs and sending a mist of diesel fuel into each chamber when the piston is near the bottom of the stroke (as indicated by a bamboo bbq spear or similar indicator)?
I appreciate those who've read this full post and welcome insights any of you may have on my no-flow-oil snag, suggestions for overcoming this snag, and other recommissioning ideas I have not mentioned. Thanks for helping me get this car back on the road.
