1 - 6 of 6 Posts
Hello to everyone:
As I was doing my regular oil change, I found that the engine had an oil leak. The level was low (the tip of the dipstick was wet) and it looks like it is coming from the driver side. I did not see any oil where the filter is located (I thought I might have not tight it enough the last time I change the oil) and it is very difficult to find the source.
I wanted to reach out to you and ask if anyone else has experienced a similar leak and what did you find it was the cause.
The odomoter marks 160K. I replaced the timing belt at 80K. Regular oil changes every 7.5K.
Thanks in advance for your help fellas.
oil filter o-ring means you don't have to kill the filter cap. most likely not leaking from there
common leaks - valve cover, tandem pump, and the turbo intake o-ring.
I replaced the turbo intake o-ring and it fixed a minor leak for me. Looks like that may be yours, if original, strongly recommend replacement of this o-ring. It's in back. remove air intake hoses to get to it.
You do have a leak in the front though, just try to trace the source.
Hello to everyone:
View attachment 4501 View attachment 4502 View attachment 4503 View attachment 4504 View attachment 4505 View attachment 4506 View attachment 4507 View attachment 4508 View attachment 4509 View attachment 4510 View attachment 4511 View attachment 4512 View attachment 4513
  1. On
  2. Hello to everyone:
    This problem is in my car
Discussion Starter #5
Update: Issue was the valve cover. For an unknown reason, the valve cover was loose completely. I bought a new valve cover gasket and replaced it. The leak has ceased.
I had a leak from the injector harness plug at the head, some "Right Stuff" gasket maker solved mine. Yours looks like your fuel hoses there need some love too...
1 - 6 of 6 Posts
