1 - 10 of 10 Posts
It's easy. Remove bottom cover, move bracket with wires and push to out of way. Remove drain plug in middle of filter canister and let drain. Then remove filter and replace with new one. Drain oil pan. Replace plug. Fill oil and enjoy.
Make sure you get the right filter, seemed impossible for me the first time. 03N 115 562
Good morning all. First time post here. Resurrecting an older thread as it's the most relatable to my inquiry. It's that time again for me to change the oil in my 2015 Jetta TDI and I was wondering if anyone is familiar of an oil filter relocating kit that they are satisfied with. I have plenty of room next to the radiator due to modifications. Again, I'm just seeking information to simplify/hasten the process for me instead of putting the car up on ramps and removing the entire belly pan/splash shield. Your input is appreciated!
1 - 10 of 10 Posts
