The manual is 23,590, DSG is 24,690. $650 destination charge
http://www.vw.com/jettasportwagen/pricelist/en/us/#/overview
engine specs
http://www.vw.com/jettasportwagen/completespecs/en/us/#/show_all
2.0l, 4 cylinder, in-line, turbocharged direct injection, Common Rail
bore
3.19 in (81.0 mm)
stroke
3.74 in (95.5 mm)
compression ratio
16,5:1
140hp @ 4,000, 236lb/ft @ 1,750-2,500 rpm
transmission gears
1- 3.77 (3.46)
2- 2.09 (2.05)
3- 1.32 (1.30)
4- 0.98 (0.90)
5- 0.98 (0.91)
6- 0.81 (0.76)
final 1-3.45 (4.12)
final 2- 2.76 (3.04)
6.5J X 16" alloy wheels
205/55 R16 H, all season tires
brakes Power assisted, dual circuit, vented 288 x 25 mm front discs and 260 x 12 mm solid rear discs
Passenger Volume 91.7 ft3 (2.60 m3)
Cargo Volume 32.8 ft3 (0.93 m3)
Cargo Volume with rear seat folded (floor to ceiling) 66.9 ft3 (1.89 m3)
Volume (Front/Rear) 50.1 ft3 (1.42 m3) / 41.6 ft3 (1.18 m3)
Head Room (Front/Rear) 38.4 in (976 mm) / 38.1 in (969 mm)
Shoulder Room (Front/Rear) 54.8 in (1,391 mm) / 53.1 in (1,348 mm)
Leg Room (Front/Rear) 41.1 in (1,045 mm) / 35.5 in (901 mm)
Wheelbase 101.5 in (2,578 mm)
Front Track 60.7 in (1,541 mm)
Rear Track 59.6 in (1,514 mm)
Length 179.4 in (4,556 mm)
Width 70.1 in (1,781 mm)
Height 59.2 in (1,504 mm)
Ground Clearance 5.4 in (138 mm)
curb weight about 3,230 or 3,285 lbs
engine specs
bore
3.19 in (81.0 mm)
stroke
3.74 in (95.5 mm)
compression ratio
16,5:1
transmission gears
1- 3.77 (3.46)
2- 2.09 (2.05)
3- 1.32 (1.30)
4- 0.98 (0.90)
5- 0.98 (0.91)
6- 0.81 (0.76)
final 1-3.45 (4.12)
