1 - 6 of 6 Posts
Hi,
Can somebody explain to me what is the role of the screw shown in the picture (red circle) ?
I took it out because I thought it was the tandem pump pressure port. The screw above is the port for measuring the
pressure of a tandem pump.
Thank you
Lucky you have posted in the correct section.
Manufacturer: Skoda, Date(s) Used: 03/2006-10/2008, Model: Octavia, Engine Code: BXE, 77Kw, 105PS, 1.9 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD) EU4, 4x4, 8v Timing belt
Sorry, I missed this rule. I created post in introduction section.
My car is not 4x4.
It may not be 4x4 my app only shows what ETKA or ElsaWin shows.
All LT's show 4x4 I don't know if they all are.
Manufacturer: VW, Date(s) Used: 04/1975-11/1982, Model: LT, LT 4x4, Engine Code: CH, 55Kw, 75PS, 2.0 Ltr, 4 Cyls, Remarks: 4x4
Manufacturer: VW, Date(s) Used: 05/1996-11/2001, Model: LT, LT 4x4, Engine Code: AGL, 105Kw, 143PS, 2.3 Ltr, 4 Cyls, Remarks: 4x4
Manufacturer: VW, Date(s) Used: 08/1988-07/1989, Model: LT, LT 4x4, Engine Code: 1G, 68Kw, 92PS, 2.4 Ltr, 6 Cyls, Remarks: Turbo Diesel, 4x4 Timing belt
Manufacturer: VW, Date(s) Used: 04/2001-07/2006, Model: LT, LT 4x4, Engine Code: BBE, 61Kw, 83PS, 2.5 Ltr, 5 Cyls, Remarks: Turbocharged Direct Injection Pumpe Düse (TDI-PD), 4x4 Timing belt
Manufacturer: VW, Date(s) Used: 01/1976-11/1982, Model: LT, LT 4x4, Engine Code: CG, 48Kw, 65PS, 2.7 Ltr, 4 Cyls, Remarks: Diesel 4x4
Manufacturer: VW, Date(s) Used: 02/2002-05/2003, Model: LT, LT 4x4, Engine Code: AUH, 116Kw, 158PS, 2.8 Ltr, 4 Cyls, Remarks: Turbocharged Direct Injection (TDI), 4x4
As taken from my new VAG Engine & Transmission Codes
Discussion Starter #5 (Edited)
I understand, I would not complaine that I have a 4x4 transmission. :)
My transmission have code JCR ( FWD ).
Although the transmission type is not currently relevant to the doubt that I have about the tandem pump.
I suspect that a nuts that I mistakenly pulled out is some kind of return valve. And now I'm not sure if a calibration of a tandem pump is required.
My tandem pump have this part number:
038 145 209 M
V14.0
My car is not 4x4.
You said your Octavia isn't 4x4 ok.
Manufacturer: Skoda, Date(s) Used: 02/2006-04/2013, Model: Octavia, Octavia II 1.9 TDI-PD, Transmission Code: JCR, Transmission Type: 5S, Remarks: 0A4 Gearbox (front-wheel drive)
The problem with ElsaWin with Skoda is they only have one database 03/2012.
As I've said: Any problems search TDI Wiki as that covers write ups and forum posts.
1 - 6 of 6 Posts
