Pedal will not change rpm after about 1000 rpm until the pedal is returned to idle position then pedal will accelerate motor. If I try and do it while the park brake is on it accelerates properly. Thanks for any help
Thanks in the process of getting a scanner to scan the jetta i changed the brake switch thinking that it was sticking , which would tell the bcm that the brake was still on and thus disabling the throttle but that didn't do anything. Same issue
