1 - 6 of 6 Posts
2000 golf TDI 204K, no codes. If the glow plug light flashes when you turn the key, starts and runs fine. but if the glow plug light doesn't come on at all, no start. sometimes you can wait a few seconds/minutes and it flashes, sometimes you wait days and it flashes. Anyone else had this problem and if so, what was the problem?
Low-hanging-fruit: Check 109 relay. Sticky or perhaps socket connection is a bit iffy (lots of times simply reseating electrical stuff resolves issues).
swapped with a known good and that fixed it. replacement OTW. thanks for replying.
Discussion Starter · #5 ·
hi there! hope your problem is solved now ..;)
yep, it was the 109. about 10 bucks @ idparts, thanks for the replies.
Discussion Starter · #6 ·
Broke the ‘bad’109 open and found the braided copper was touching a ‘prong’…..not good. Essentially it was a short. Pressed the braided copper down. And added a small piece of electrical tape to the prong, reinstalled and have had no problem since. So now I’ve got an extra.
Circuit component Office equipment Machine Rectangle Household appliance accessory
1 - 6 of 6 Posts
