2992 Jetta TDI , hard start even at 90 degrees air temp, after it starts which takes 2 or 3 attempts at 25 seconds each, it will restart in 2 seconds, i check for power at the #1 cylinder glow plug and nothing. glow plugs are new bosh same part # as i removed, Hard starting started about 60 days after changing them.
Does any body know where the fuse is ?? I suspect it to be a fuse over a relay . your thoughs.
Thanks
Thanks
