1 - 7 of 7 Posts
Hi
First post on this form
Have retro fitted a VW bluetooth kit to my T5 transporter 2010, can't seem to get the thing working, I get to the phone menu in the mfd and it seems to freeze up I can't select the phone search or help options or exit the phone menu without unpluging the blutooth kit
Not using the mfsw, just the stalk buttons and he kit is 3C8 035 730A
Any help appreciated and sorry if this is in the wrong place
Thanks
Discussion Starter · #2 ·
Fault codes
Also I can't understand why I would be getting all these faults, Maybe the box is faulty
Address 77: Telephone Labels: 3C0-035-730.lbl
Control Module Part Number: 3C8 035 730 A HW: 3C8 035 730 A
Component and/or Version: Telefon 007 0078
Software Coding: 020000000000000000000000
Work Shop Code: WSC 00000 000 00000
ASAM Dataset: EV_UHVPremi A01005 (VN75)
VCID: 2142607281A1
5 Faults Found:
9455635 - Telephone Microphone
B1048 13 [009] - Open Circuit
Freeze Frame:
Fault Status: 00000001
Fault Priority: 4
Fault Frequency: 1
Reset counter: 43
Mileage: 16487 km
Date: 2013.14.17
Time: 10:48:27
9458451 - Cellular Antenna:
B1053 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 43
Mileage: 16487 km
Date: 2013.14.17
Time: 10:48:27
9457939 - Telephone baseplate
B1051 13 [009] - Open Circuit
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 43
Mileage: 16487 km
Date: 2013.14.17
Time: 10:48:27
9458193 - Control Module for Cellular Telephone
B1052 14 [009] - Short to Ground
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 43
Mileage: 16487 km
Date: 2013.14.17
Time: 10:48:27
13636352 - Control Module Not Coded
U1013 00 [009] - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 43
Mileage: 16487 km
Date: 2013.14.17
Time: 10:48:27
Discussion Starter · #4 ·
Coding
Thanks for the reply
Ive found very little about the coding but managed to find this below and copied the coding, I thought I'd cracked it because it cleared the faults but when I went in again it brought 3 faults back and the mfd still just freezes up
Address 77: Telephone (J412) Labels: 3C0-035-730.lbl
Part No SW: 3C8 035 730 A HW: 3C8 035 730 A
Component: Telefon 007 0078
Revision: -------- Serial number: 35909603008345
Coding: 020000000100000000010000
Shop #: WSC 01357 011 00200
ROD: EV_UHVPremi.rod
Try posting your scan in the ross tech section at the top of this subforum. It will get their attention and they may know the correct coding. Make sure the title has your model and year in addition to the problem to be more descriptive.
Discussion Starter · #6 ·
Thanks I will try that
Think I'm going to swap the box first though with the suppliers and see from there
Thanks
Discussion Starter · #7 ·
Coding 3c8035730A
Found a bit of info regarding coding but still no Joy
Code should be something like
020000010100010000000400
found long coding labels and pasted them into the label file, translated them -
,00,Keine fallback language
LC, 00, 0 ~ 7, 01, English
LC, 00, 0 ~ 7, 02, English
LC, 00, 0 ~ 7, 03, French
LC, 00, 0 ~ 7, 05, Italian
LC, 00, 0 ~ 7, 06, Portuguese
LC, 00, 0 ~ 7, 08, Tschechie
LC, 01, 0 ~ 7, 00, voice control active
LC, 01, 0 ~ 7, 01, no language service
LC, 02, 0 ~ 7, 00, audio parameter set microphone type VW 1
LC, 02, 0 ~ 7, 01, audio parameter set microphone type VW 2
LC, 02, 0 ~ 7, 02, audio parameter set microphone type VW 3
LC, 02, 0 ~ 7, 03, audio parameter set microphone type VW 4
LC, 02, 0 ~ 7, 10, audio parameter set microphone type Audi 1
LC, 02, 0 ~ 7, 11, audio parameter set microphone type Audi 2
LC, 02, 0 ~ 7, 12, audio parameter set microphone type Audi 3
LC, 02, 0 ~ 7, 13, audio parameter set microphone type Audi 4
LC, 03, 0 ~ 7, 00, active antenna diagnostic
LC, 03, 0 ~ 7, 01, antenna diagnostic off when disabled
LC, 04, 0 ~ 7, 00, baseplate active monitoring
LC, 04, 0 ~ 7, 01, monitoring baseplate off when disabled
LC, 05, 0 ~ 7, 00, cooperative mute active
LC, 05, 0 ~ 7, 01, cooperative mute off when disabled
LC, 06, 0 ~ 7, 00, 3 button module active / SMS write possible
LC, 06, 0 ~ 7, 01, 3 button module deaktiv / SMS write possible
LC, 06, 0 ~ 7, 10, 3 button module active / SMS write not possible
LC, 06, 0 ~ 7, 11, 3-button module deaktiv / SMS write not possible
LC, 07, 0 ~ 7, 00, BT-audio active / active multimedia media context
LC, 07, 0 ~ 7, 01, BT-audio off when disabled / Active multimedia media context
LC, 07, 0 ~ 7, 10, BT-audio active / multi media context off when disabled
LC, 07, 0 ~ 7, 11, BT-audio off when disabled / multi media context off when disabled
LC, 08, 0 ~ 7, 00, THB cradle installed
LC, 08, 0 ~ 7, 01, VDA cradle installed
LC, 08, 0 ~ 7, 10, Paragon cradle installed
LC, 09, 0 ~ 7, 00, cry for help disabled
LC, 09, 0 ~ 7, 01, cry for help enabled (not supported!)
LC, 10, 0 ~ 7, 01, fuel type petrol
LC, 10, 0 ~ 7, 04, fuel type diesel
LC, 10, 0 ~ 7, 05 LPG fuel type
LC, 10, 0 ~ 7, 06, natural gas fuel type
LC, 10, 0 ~ 7, 08, fuel type, electric
LC, 10, 0 ~ 7, 10, hydrogen fuel type
LC, 11, 0 ~ 7, 00, category (unknown)
1 - 7 of 7 Posts
