new to this forum, been reading for a while. so good info here I see, daughter totaled the jetta tdi automatic and I found a beetle pd dsg with dmf problems . jetta had no problems with 60k miles , beetle has 150k and seems it is going to be a project. I will try not to be a pest. it has a problem starting every time I want it to. Turn the key and nothing , then sometimes it starts slowly. Suspect the load reduction relay today. have not hit the starter in the head yet . Tarzan out
Yes, you're not supposed to hit the starter so just hit it gently :D Check all grounds and battery. Definitely do change the DMF. I'm currently looking for a writeup on this with step by step pics so if you want to help out, please do! There is also a writeup contest with prize to reward the best writeups, check out the guidelines and tips in the general section.welcometomyturbodies
