Hello fellow darkside owners.
I'm Foxy from the UK.........its been about cars since I can remember.
Had all the Golf marques - (not a mk6 yet) and many many other makes and models too.
Probably 40+ cars now between myself and Mrs F.... and we were born mid 1960s!
I have been on UK-MKIVs scene since 2002 and driven the hallowed Nurburgring in my modded Mk5 Golf three times.
I currently have a Skoda Octavia VRS 2007 170bhp TDi........totally standard.
In the sideline I have a 2008 VW Jetta to replace it.
( I have a t4 van with 1.9Tdi conversion and Mk2 Golf GTi 1989 to keep me busy too!)
The issue is with the jetta.
The ECU got ruined when a small "overheating" issue fried some wiring - it got rather warm and then wet.
It also damaged the clocks (instruments) which show a permanent short fault on fuel sender (on vag-com).
The fuel gauge and external temperature sensor now dont work.
I need to replace ECU and clocks from a similar donor car which I have indeed tracked down.
Trouble is, the donor set has no keys.
I am sure I can pull the SKC off the ECU/clocks in order to programme a virgin transponder chip.
Can anyone "chip" in !!?
