Looking to see if removing the headliner is worth trying myself. I have already done seat swap, but headliner seems tricky. Need to replace antenna base and would like to have headliner re-done. By the way this forum rocks!!
Redone in what? I've redone headliners using replacement "mousefur" foam backed liners. You normally use contact glue. The reason it must have some padding is so it doesn't show the bumps and lines in the headliner.
It's not that hard, you just have to loosen the side pillars and stuff like the overhead console/sunvisors.
