My my name is Tony in Michigan. I am also new to the TDI world. I just purchased a 05 Passat TDI. Currently I working through some issues. It currently will not start. The motor turns over and comes close to starting but just wont. I changed the filter this morning but this made no difference. The car will start for a couple seconds with starting fluid. So it is defiantly is a fuel delivery issue. The lift pump does turn on but I have not pressure checked it yet.
Welcome to the forum.
How long is a piece of string?
That could be many things.
Does the fuel pump prime when you turn the ignition on?
Thank you! So far I have changed the lift pump in the tank. The original one was putting out pressure but not well and sounded bad. Tomorrow I am going to replace the check valve on the fuel filter as well as put new fuel lines on. The rubber lines are not in good shape and I don’t want to have any leaking issues. Tomorrow I will scan it and check for a crank sensor input. Last time I checked I didn’t notice if the rpm gauge moved while cranking. Thank you again
