Hi all,
new member here. 2001 Golf. When leaving works yesterday, the engine mount "ear" on the engine broke off. I need to replace the timing belt and the pass radiator fan as well :(
I joined the forum for the timing belt procedure...but I can post pictures (broken mount & why I need to replace timing belt) after I fix the car, most likely in 2 weeks. Ask away if you would like something specific.
Thanks,
Math
Thanks chittychittybangbang.
I am aware of the van gogh fix and will order it as soon as I decide what I will do with the car... It has a lot of issues right now and I need to decide if I keep it or if it will be replaced.
I will take pictures and might do a write-up as well for the van gogh fix itself but not the timing belt since you did an excellent one yourself. Other repairs I need to do and might do write-ups on if required are : door switch repair, antenna base seal replacement, radiator fan replacement (and electrical repair), cabin dust filter replacement, fuel filter replacement, air filter replacement & snowscreen cleaning, manual trans fluid change, rear suspension bushings, complete rear brake job including calipers, downpipe r & r (need to weld it, cracked right behind catalyst), skidplate install, and I may do a radiator support replacement as well.
Let me know which of these procedures do not have write-ups and I might do them if I keep the car.
Math
