So I finally got around to replacing the cam shaft, lifters and bearings. I have been busy with work and trying to get hay in around the rain.
I followed the directions on this site very carefully since it was the first time I have messed with the timing belt and/or cam shaft. The directions are fantastic!! I put it back together and when I tried to start it, it ran for 2-3 seconds and then died. I searched out some threads and it seems like it ran off the fuel that was remaining between the injectors and pump for those couple of seconds. I bled the the tandem pump by opening the plug between the 2 - 5mm bolts on the pump, turning the key on about 5 times without starting. I then tried to turn the engine over with the plug still loose. Fuel definetly came out. I then tightened the plug and tried to start again, no luck. I checked to make sure the lift pump was working by disconnecting the supply line at the fuel filter, and it is working fine. I disconnected the tandem pump return line at the fuel filter and used my mighty might to pull fuel through. Lots of air came out. I vacuumed about a 1/2 cup of fuel and air bubbles came out the entire time. I hooked the line back up and it still would not start. I am now going to pull fuel through the return line with the mighty mite again until I don't see air anymore.
It seems to me, I probably reassembled everything okay if it ran for a few seconds. And yes, I did manually turn the cam pulley 2 complete revolutions to make sure there was no collision of the valves and pistons. A friend of mine at work has a VAG COM set-up that will allow me to look at timing and such, but I won't get that until tomorrow.
Is there a better way to bleed the pump then the mighty might?
Any other suggestions on what I might check?
