Hi im a newbie and have a question regarding limp mode.
No problems personally but my
2006 VW passat 2.0 TDI 140bhp BKP 120,000 miles
goes into limp mode after driving for approx 25-30 miles. Around town is fine
Vag shows
Control Module Part Number: 03G 906 018 CD
Component and/or Version: R4 2.0l PPD1.5 G 9627
Software Coding: 0000072
Work Shop Code: WSC 00199
1 Fault Found:
16683 - Boost Pressure Regulation: Control Range Not Reached
P0299 - 006 - Short to Plus - Intermittent
Normally around town boost is fine.
Recently changed the manifold flap as was full of oil and two teeth were missing which blew fuse which also controlled air con. It did this before I changed the flap so the flap is not the problem now.
Also checked and cleaned EGR valve which is ok.
Has anybody any ideas would be much appreciated.
Vag shows
1 Fault Found:
