Hi, I just bough a 2005.5 jetta (1k) 5 speed manual at an auto auction. It has 220K miles on it and very little history. Since it had very little history I had the timing belt, water pump, and thermostat replaced. The shop that replaced the timing belt also recommended after looking at the vehicle to replace the EGR cooler, o2 sensor, fuel filter, and oil / oil filter. The car ran pretty good for about a month, but has started going into limp mode and is blowing black smoke out the back like crazy. The symptoms have come on very gradually. First it was occasional limp mode. I would feel a slight stutter usually when going down hill. I typically wouldn't think anything of it until I tried going up a hill and would have no power. Turning the car off and then back on again brought back power. Over the last month it has gotten progressively worse and goes into limp mode all the time. Recently, in addition to the limp mode the car is blowing massive amounts of black smoke. I also have trouble at times getting the RPMS over 2k. If I am successful in getting more than 2K rpms this is when it blows the black smoke. The car usual accelerates pretty well after this and the turbo will kick in. Since I am tired of paying a shop all my $$ I have started going through the Limp mode and low power DYI list and I have purchased the vagcom cable from ross tech. I get two fault codes on the vagcom, 000305 - Oxygen (lambda) sensor b1 s1: signal too low - Intermittent, and 001027 EGR Valve (N18) malfunction - Intermittent. I have unplugged the MAF and it seems to run a little better without the MAF, but still not great. The screen shots of the vagcom maf test are different than what I have in my version of the vagcom so I am still working on that test.
I have very little experience with this type of thing, but I am hoping to learn.
Any help that you all can provide would be greatly appreciated.
